 Post subject: Maxtor DiamondMax Plus 9 160GB ATA/133 HDD burnt PCB board
PostPosted: July 30th, 2009, 3:47
My maxtor hard drive pcb board's square chip caught on fire, and completely rendered the hdd usuable.
Is it safe to replace the pcb board?
HDD info:
MA6Y160P0
Code: YAR41BW0
K,M,G,D
M88FYB
301862101
CALYPSO/KOT_P/THERM
 Post subject: Re: Maxtor DiamondMax Plus 9 160GB ATA/133 HDD burnt PCB board
PostPosted: July 30th, 2009, 3:56
On this model you can use any M8FYB pcb.
But you can have damaged preamp as well wich is common on this model + this problem.
If your preamp is short, the new pcb will be gone too.
If your data is really important, i suggest to find a pro near you.
This problem can be cheap.
Best Regards,
Janos
PostPosted: July 30th, 2009, 4:02
Wow, that was a quick response :D.
How would I check if it had a damaged preamp. Last time it was on and on fire, I could hear the hard drive spin normally.
I should go to bed as I have a dmv written test early in the morning D:
PostPosted: July 30th, 2009, 4:23
read this:
howto-how-replace-maxtor-calypso-iii-board-t5977-60.html
Spasavanje podataka
PostPosted: July 30th, 2009, 7:56
If you are looking for a PCB, I can help.
But if you data are quite important, find a pro near you would be a good choice.
Thanks.
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: July 31st, 2009, 19:37
how would u explain the fire
1. did the whole hdd burn
2. Just a crackn noise from the hdd due to a blow out on the pcb
3. Smoke coming from the pcb
4. Bad smell from the pcb.
which 1.
If it is totally burnt get the expert
If the pcb is out and the data in minor to u buy a new pcb
if the data is of high value get an eval from expert.
PostPosted: August 1st, 2009, 19:38
Okay, here's a bad quality photo. My phone's camera doesn't have autofocus
PostPosted: August 1st, 2009, 22:35
Yep, I can see it even with this low resolution photo...
You have to have a replacement PCB at least!!
PostPosted: August 1st, 2009, 23:01
SMOOTH drive chip got fire, try swap PCB.
Users browsing this forum: Google [Bot] and 76 guests
