 Post subject: any known technique to make the heads stick to platters?
PostPosted: August 18th, 2009, 15:26
Does anyone know of a sure technique to make the heads stick to platters? I am looking for something more reliable then giving the drive a good smack.
 Post subject: Re: any known technique to make the heads stick to platters?
PostPosted: August 18th, 2009, 15:33
super glue.
PostPosted: August 18th, 2009, 15:40
Isn't that counter productive to what this forum is all about?
PostPosted: August 18th, 2009, 15:44
HDD Spaz wrote:
super glue.
yeah... not exaclty what i had in mind :lol:
Yep. It sure is :mrgreen: Well on second thought actually this is exaclty what this forum is about :lol:
PostPosted: August 18th, 2009, 16:49
I guess somebody has recovered data and had a quote declined.
Try throwing it out of a window while is being erased, you will need a usb adapter and a long usb cable. :lol:
PostPosted: August 18th, 2009, 17:01
I don't engage in unethical practices for your information!
As I see, some people have just to much time on their hands :lol:
PostPosted: August 18th, 2009, 17:02
Seriously,
If anyone can help, please pm.
PostPosted: August 18th, 2009, 17:41
Trusting that it is for ethical purposes........why not just gently move the heads off the ramp and back onto the platters whilst turning the spindle with your other hand.
As far as ethics go, you should have some form of pre-authorisation in place so that you never get to the stage where you carry out work and then your customer declines the job.
Data Recovery Ireland
PostPosted: August 18th, 2009, 17:55
CK,
Thanks for the reply. It is only for R&D purpose.
In other words I want to duplicate the scenario where heads are stuck to the platters solid. I need about 10 - 15 drives for testing. I don't think that moving the heads off and on to the platter will make them stick. I am sure you all know the case where the heads are stuck solid to the platters and you can not move the heads with conventional methods without damage. (yeah... the really solid stuck cases.)
Thanks,
Users browsing this forum: No registered users and 302 guests
