Forum rules
 Post subject: Duplicate Disk Signatures
PostPosted: August 21st, 2009, 10:59
I recently restored a W7 partition and chose to restore it to a new drive restoring both the MBR and disk signature. Now I want to use the old drive as either an internal or external backup and I dont think it is a good idea to have two drives with the same disk signature present in the same instance machine.
Can someone recommend a procedure for creating a new unique disk signature on the old drive so that it can be used in the same machine as the new drive?
 Post subject: Re: Duplicate Disk Signatures
PostPosted: August 21st, 2009, 13:25
Load the disk into another computer, then wipe sector 0. Put it back into the original computer and initialise and format the disk.
https://www.mjm.co.uk/
PostPosted: August 21st, 2009, 13:37
Sounds pretty straightforward. Hate to sound like such a novice but which tool do you recommend for the sector 0 wipe? Also is there an easy way to actually view the disk signatures to confirm that they are in fact dups?
PostPosted: August 21st, 2009, 14:09
Or just boot to an MHDD disk and erase the one you want to erase.
Users browsing this forum: No registered users and 84 guests
