 Post subject: 7200.11 does not spin up...
PostPosted: August 18th, 2009, 4:31
Hi, I have some problem with this disk. Motor starts but disk is clicking about 8 times and motor stops. Correct me if I'm wrong, but i suspect problem with electronic. Disk is seen in mhdd with 0LBA size. Terminal is not locked, and when I type U command it refers spinup error... What details should be the same on donnor disk?
Best Regards
Pawel
 Post subject: Re: 7200.11 does not spin up...
PostPosted: August 18th, 2009, 6:28
Firmware corruption. Search for seagate 7200.11 0lba solution.
Zero Alpha: zeroalpha.com.au
PostPosted: August 18th, 2009, 11:20
are U sure?
for me it seems head/preamp (PCB 5%) related...
What do u want to do with it?
PostPosted: August 18th, 2009, 14:11
It's a disk of my close friend. He ask his employee to try to fix it. I suspect he smashed pcb (smooth ic) when he tries to unlock terminal - PCB is very hot. All I want to do is swap pcb resolder rom and check if I get the data or access to service area. One thing I'm afraid is that damaged preamp can destroy the donnor pcb, can I check if there is short-circuit using standard digital multimeter, or not?
PostPosted: August 18th, 2009, 15:07
more or less. U can check at least wether power lines are OK or shorted.
PostPosted: August 19th, 2009, 12:02
I've almost the same problem. HDD motor does not start an clicking. smooth chip's all pins are short circuit. I'm looking for a smooth chip to change it. The chip is 100369972.
PostPosted: August 19th, 2009, 12:43
how is that possible?
www.datarecoveryne.com
PostPosted: August 19th, 2009, 12:52
I mean it makes noise like beep per second. Motor does not spin up...
PostPosted: August 19th, 2009, 13:03
Oh, sounds like your spindle is stuck.
PostPosted: August 21st, 2009, 12:24
a diode on 12v line was s/c. I changed with the new one then I measured the motor voltages..of course I measured nothing. All of the pins of smooth chip are now s/c. I need a new SMOOTH 100369972 to change it. Anyone help me ?
PostPosted: August 21st, 2009, 12:45
And you want to change the combo IC ? The whole PCB is fried, you better try with new one and do what you have to do with PCB change....
PostPosted: August 22nd, 2009, 7:50
I dont know all the chips ok or not. And The whole PCB is not fried. As I said before All of the pins of smooth chip are s/c..
PostPosted: August 22nd, 2009, 8:46
OK. good luck then.
Users browsing this forum: Google [Bot] and 127 guests
