 Post subject: TOSHIBA 30GB MICRODRIVE
PostPosted: August 22nd, 2009, 10:23
Hi,First salute all comunity ,this is my first post .Sorry for my english ,I'm foreign.Can somebody help me about the reparation of mk3008gal microdrive?My question is: ¿can i take a good motherboard /electronic board of a good mk3008 toshiba´s drive and put it on other mk3008 gal that electronics is faulty?I´m trying to make a good drive from two faulty drives,the first with good mechanical parts and the second with good electronical parts ,Is it possible?Thanks in advance.
 Post subject: Re: TOSHIBA 30GB MICRODRIVE
PostPosted: August 22nd, 2009, 10:52
No it's not. Well, not without a LOT of trouble.
PostPosted: August 22nd, 2009, 11:26
thanks to respond.Where is the problem?is the electronics married with the mechanical parts?Password ,locked?Can you give more information,please?
PostPosted: August 22nd, 2009, 12:05
Unlike most other drives, Toshiba drives have almost all their unique and adaptive data (incuding s/n etc) on the PCB.
PostPosted: August 22nd, 2009, 12:23
Thanks ,is this information inside the micro 88i6313-gba1?Where is in the mechanical part?is it possible to program /flash?
PostPosted: August 22nd, 2009, 15:07
Not by you.
PostPosted: August 22nd, 2009, 15:34
And then,Can you do this?Is top secret information?Information that cost a lot of money,isn't it?
PostPosted: August 22nd, 2009, 15:48
If you cannot buy knowledge because it's not for sale, you can always buy a solution for your problem. Can't say more than this.
PostPosted: August 23rd, 2009, 17:49
I see.We are talking about a lot of money.Fine,if somebody wants to join knowledge to study this drives,to unlock them ,you are welcome.I think the solution goes to study the marvell micro that stay in PCB ,and try to unlock them with the master password.Does somebody know where is the serial or password in the mechanical parts?Is it in a particular sector?Thanks.
PostPosted: August 23rd, 2009, 20:05
I think what the guys are trying to say is if you don't have the knowledge then you are very likely to mess up your drive if you open/try to fix it by yourself.
Basically you need tools which you probably won't have to program the PCB. I would send it to an expert.
Cheers, Matt
PostPosted: August 24th, 2009, 1:28
@biopuerto,
the wheel doesn't need to be reinvented. If you want your drive data, the answer is yes, if your idea is to get info for free then the answer is no.
PostPosted: August 24th, 2009, 1:29
@biopuerto,
Users browsing this forum: ccc, Majestic-12 [Bot] and 58 guests
cron
