 Post subject: WD1200AB-22CBA 1
PostPosted: August 23rd, 2009, 13:47
Platters rotate, head crosses to middle , quickly shoots back to center, disk stops rotating. Need someone relatively inexpensive. Need to recover family photos.
 Post subject: Re: WD1200AB-22CBA 1
PostPosted: August 23rd, 2009, 14:15
you wont find that here. You have opened it and made things ten times worse and ten times more expensive.
PostPosted: August 23rd, 2009, 14:21
I'm afraid not here nor elsewhere. And all this just because you opened it. Good luck, anyway.
PostPosted: August 23rd, 2009, 14:31
so it cant be opened?
PostPosted: August 23rd, 2009, 14:56
It WOULDN'T HAVE BEEN , instead.
PostPosted: August 23rd, 2009, 14:57
Think you told us .... you did ....
So... as far as I do understand english .... that means ... you can
... but, what you where told .... you should NOT have done it.
PostPosted: August 23rd, 2009, 14:58
some other issue? What is estimated cost of something like this?
PostPosted: August 23rd, 2009, 15:04
At present : likely head problem and/or firmware issue (original problem) , plus (added by you) : media contamination and possible damage , loss of alignment.
For me it's not less than 2500-3000 EUR + VAT and need to see the drive if it is still recoverable.
PostPosted: August 23rd, 2009, 20:11
I think you're one step ahead of yourself... why not post the original symptoms before opening the drive?
Users browsing this forum: Google [Bot] and 140 guests
