Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Dealing with stuck motor bearings
PostPosted: March 24th, 2009, 5:02
hddinfo wrote:
has anybody got tools to remove heads (100 % safe) from 7200.9 and higher?
there are commercial tools available, but it may be an idea to try to design some of your own, just takes a little thought.
PostPosted: March 24th, 2009, 5:07
Banned User
i do have tool made myself (100 % safe)
just wanted to know other users opinion
thanks
PostPosted: August 30th, 2009, 2:01
let us have a look at your head removal tool Mr. Pepe
PostPosted: August 31st, 2009, 3:01
PostPosted: August 30th, 2016, 7:02
is this suitable for all seagate drives?
PostPosted: August 30th, 2016, 11:07
jono-ats wrote:
I made a number of extra tools -- I'll PM you privately.
Do you still have this tool for sale ?
What drives (brands n families) its designed ?
PostPosted: March 19th, 2018, 15:28
i have a St31500341as with motor stuck issue.
i released the motor forcely but unfortunately i didn't read this topic before i try.
i didn't remove the heads.
Disk spins noisly now.. heads wanna try but can't find the SA.
Are heads gone?
PostPosted: March 19th, 2018, 16:13
Well,
If They Were Floating In Air By The Slower Rotation Then No ,If Not Floating Then Platter Layer Is Gone With Heads
PostPosted: March 20th, 2018, 4:01
Amarbir[CDR-Labs] wrote:
Well,
it's obvious that head's moving and try to find SA. but it can't..
What is the problem?
PostPosted: March 20th, 2018, 9:44
They are moving now, they weren´t moving before. So, when you forcefully moved the motor/platters, you damaged the heads.
