 Post subject: Problem with HDD maxtor diamond plus9
PostPosted: September 1st, 2009, 20:56
Hello. I am new to the forum. Excuse my bad English.
I have a problem with a Maxtor HDD model 6Y060L0420471 , CODE YAR41VW0. Firmware D6FYP1 chip Ardent C5-C1. The chip Smooth was burned by problems in the power supply of the pc. I probe amplifier and is fine (+5 volt and -5volt). Know if the motor is fine. Some form of test? Measured resistance in the four pins is between 1,9 to 2,9 OHMS. This is correct ?
I get the following pcb, but not if they are compatible with this hdd.
Hdd 60 gb CODE YAR41VW0 Firmware g6fya chip Ardent C8-C1 - OR-
HDD 80 gb CODE YAR41BWO, Firmware F4FYA.
If not compatible, I can swap in one of two pcb the firmware rom chip for the rom chip D6 on my HDD?
there any other solution? Since I do not get the exact pcb here.
thanks.
 Post subject: Re: Problem with HDD maxtor diamond plus9
PostPosted: September 2nd, 2009, 2:07
If with both PCBs (at least the 1st should work) the drive does not calibrate or makes the typical Maxtor sound "zzzzingg... zziiinnng.... zzziiingg..." , most likely you have fried preamplifier OR the pcb is totally incompatible so try another.
If you have partial calibration you have either a wrong PCB or damage to the service area. Notice that if you have some certain damage at preamp level, you can fry the new PCB also...
NOTE : when I see such damage, I never swap PCB at first , I make an extensive check of the headstack with special equipment and... knowledge. (NO I won't share) just to avoid damage of spare PCB or searching for a failure that is not there.
PostPosted: September 2nd, 2009, 5:38
Shame on U for not sharing, U did not have to be sooo blunt, have U not ever sent a pm/email to a mate for some help on a drive. Just curious, why did u then tell him to check the headstack. Hope U have a good team spirit in ur work office/lab.
:o
peace out
PostPosted: September 2nd, 2009, 13:09
Thanks for the quick response.
I do the test with the PCB and then I commented.
Best regards.
PostPosted: September 2nd, 2009, 15:26
You don't know the people who I am in contact with. Period.
PostPosted: September 2nd, 2009, 15:48
@BlackST
Take it easy I know u got the contacts since u took a loooooooong vacation
"Where in the world is BlackST?"
:wink:
 Post subject: Re: Problem with HDD maxtor diamond plus9 (now works)!
PostPosted: September 16th, 2009, 0:02
hi. Finally I was able to walk again maxtor disk.
But the board (60 gb Hdd Firmware YAR41VW0 CODE chip g6fya Ardent C8-C1) was not correct the code was YAR41BWO. But buy the same. Of course not work.
But I read here:
http://www.deadharddrive.com/forums/viewtopic.php?p=762
Only a matter of changing the ROM chip of my broken board and installed the new board (YAR41BWO).
And to make it work.
Thanks for your help.
Users browsing this forum: Google [Bot] and 284 guests
