 Post subject: ST980011A - 80gb pata
PostPosted: September 12th, 2009, 7:59
Hi to all,
Have this in a seagate disk
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Head Mask FFFF - Switch to full int.
Spin Ready
Application code incompatible with serial flash code
F>
Anyone can give an opinion what can i do here,
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: ST980011A - 80gb pata
PostPosted: September 12th, 2009, 9:27
Somebody swapped the pcb and forgot to swap it back...
PostPosted: September 12th, 2009, 11:17
You need either the original PCB or its ROM, or as I believe there is no adaptive information on old Seagates, so you could get lucky with an exact matching PCB with same ROM.
Personally, best bet is to ask for native PCB.
PostPosted: September 12th, 2009, 11:24
What is the firmware on drive ?
PostPosted: September 12th, 2009, 11:28
Thanks,
Yes i know i will get lucky in find the same PCB, but i have almost 12 all different from this one.
The FW is 3.06.
ZeBong
" Россия еще раз"
PostPosted: September 12th, 2009, 17:56
You need pcb with M14 code .
PostPosted: September 12th, 2009, 19:33
Hi, yes i think i try that one and did not work the same appear in terminal.
i will try it and post here the logs in terminal.
ZeBong
" Россия еще раз"
PostPosted: September 13th, 2009, 4:46
Try S15 also .
PostPosted: September 13th, 2009, 7:51
Or you could load the existing ROM with correct ROM from another drive or resource file.
https://www.mjm.co.uk/
PostPosted: September 15th, 2009, 12:02
Thanks to all,
Patient is : 100282774 F 6514GSAY
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
F>
i try this one 100282774 C 64119VMM
i have this in terminal
ALPINE - 1_Disk M.14 01-16-03 11:51
Head Mask 0000 - Switch to full int.
Spin Ready
F>
Them i try this one : 100282774 E 343247AX
Spin Ready
F>
LAST ONE : 100282774 E 3425YQ6M
Buzz - Head Mask 0000 - Switch to full int.
Spin Ready
F>
and i dont have a loader for the M-21
ZeBong
" Россия еще раз"
PostPosted: September 15th, 2009, 13:35
THANKS
S-15 SOLVE :D
ZeBong
" Россия еще раз"
cron
