Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Seagate 7200.11 Firmware issue: HP24 Firmware
PostPosted: March 26th, 2009, 12:05
Hello all,
I am sure everyone is familiar with the firmware issue afflicting the seagate 7200.11 series drives. But I have an interesting case. This drive is showing symptoms of the Always BSY bug, but standard procedures are not working, and I can't seem to find a workaround. Here is the terminal log:
LED:000000CC FAddr:0024900D
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.156 msecs
F3 2>U
Obviously in between command Z and U I am performing the proper "procedure" but The drive acts as if that never took place. This is the first time i have worked with a drive with the HP24 firmware, so obviously there must be some "extra step" that needs to be taken here. I was wondering if anyone had discovered the workaround for this drive.
 Post subject: Re: Seagate 7200.11 Firmware issue: HP24 Firmware
PostPosted: March 26th, 2009, 15:02
Pardon the silly question : was the PCB isolated from the drive between steps 1 and 2? (It should be.)
PostPosted: March 26th, 2009, 18:58
Instead of only spindle connector isolation, complete PCB removal was needed. Everything else afterwards is "as normal"
PostPosted: March 27th, 2009, 5:10
firmware HP24 does not allow terminal access after reconnection of PCB to HDA.
PostPosted: March 27th, 2009, 5:16
It does, but you've got to do it slightly differently.
I did one this week :-)
Sean
PostPosted: March 27th, 2009, 7:34
PostPosted: May 22nd, 2009, 9:36
pcimage, i am having the same problem. Can you PM me and let me know how you got the terminal to detect after putting the PCB back on? I am getting the same problem (terminal time out). Thanks!
PostPosted: May 23rd, 2009, 5:17
There two methods of disconnecting pcb.
motor connectors as per ace and pcb to hda as per aviko and others.
Also there's method of shorting two pins without pcb disconnect.
In this case disconnect pcb to hda, power up, and only AFTER
motor stops spinning, do CTRL Z, then follow typical procedure.
besides, use standard terminal program like in windows, works better than ace
and it's free. I get lots of 7200.11 from ace udma owners, cause they don't want
to use terminal :shock:
PostPosted: May 23rd, 2009, 9:38
You have PM
PostPosted: May 24th, 2009, 16:37
I have ace UDMA and standalone RS232 connection for Terminal. I agree, some cases basic terminal from PC is just as good, if not in some cases more reliable.
PostPosted: May 24th, 2009, 16:57
Wow, heh.
PostPosted: May 24th, 2009, 18:31
After spending a lot of $ they do outsource repair?
PostPosted: May 25th, 2009, 5:01
I doubt many would...
PostPosted: September 12th, 2009, 14:39
Sean
Just in case you don't check PM's, I'd appreciate knowing the "differences" between accessing the HP24 vs. the SD15 flashed drives...
Thanks!
Ran
PostPosted: September 13th, 2009, 10:27
I too have the same problem with the terminal baud rate issue on an HP24 FW drive. Could you help?
PostPosted: September 13th, 2009, 11:16
Sometimes the solutions found on the internet brick drives beyond "average Joe" repair... :mrgreen:
PostPosted: September 13th, 2009, 16:03
True, but since I already have a replacement drive coming from Newegg, this is more or less a, "so what if it bricks - it's already a doorstop" attempt.
R
PostPosted: October 20th, 2009, 15:17
Can you tell us what needs to be done differently? Thanks
Sean
PostPosted: October 20th, 2009, 15:30
Not in open forum I won't no, nor to "newbies" with no DR experience.
Sorry if that sounds harsh or "keeping secrets" but I don't want to be held responsble for people bricking their drives irrepairably.
No offence is meant or intended.
PostPosted: October 20th, 2009, 15:44
Can you PM me? The HDD is dead to me as of right now. I'm trying to recover it.
