 Post subject: WD400BB-OOJHCO
PostPosted: September 12th, 2009, 2:24
hI, I have this drive a WD 400BB-00jhc0. It's a one head one platter disk. I have a bad head and looking for donor , i tried a same hard disk bought rfom ebay but i was surprised to see that the donor had the head UNDER the platter and mine has the head ON TOP of the platter. how can i fnd a right replacement???
customers disk
WD400BB-00JHCO
DATE 09AUG 2005
DCM:HSBHNTJCH
P/N : WD400BB-00JHC0
S/N:WMAMC4669223
Donor disk
WD400BB-00JHCO
DATE 18 OCT 2005
DCM:HSBHNTJCH
S/N : WMAMA6660638
Both are product of Malaysia
Pcb's look the same
Thank you in advance
 Post subject: Re: WD400BB-OOJHCO
PostPosted: September 14th, 2009, 3:07
You could try with a WD800BB; that one has two heads.
Dobre
Murphy was an optimist
PostPosted: September 14th, 2009, 3:14
Yep, I always use a WD800 if I have to buy in.
PostPosted: September 14th, 2009, 7:55
so i will just use a wd800bb and disable the other head?
PostPosted: September 14th, 2009, 8:39
Correct.
Dobre
PostPosted: September 14th, 2009, 9:14
Well, you don't even have to disable it. It'll already be disabled in the ROM.
PostPosted: September 18th, 2009, 1:20
Something strange is happening . It's still clicking..usually it's a board problem from my small experience.. I thought it could be heads so i changed them used from a wd800bb but still nothing. Spin up, clicking a few times , spin down and reports ready. I can work only in kernel mode i tried combinations of head disabling but still nothing..
Any ideas??
PostPosted: September 19th, 2009, 13:09
Could be one of the following:
Poor diagnosis.
Bad swap.
Head incompatibility.
and etc.
www.datarecoveryne.com
PostPosted: November 16th, 2009, 0:53
Hi again,
no clicking i was usning bad heads, now it starts normally i can work in normal mode , all service modules read ok, but a sabre id , anyone has
wd400bb-oojhco
09 aug 2005
dcm: HSBHNTJCH
WMAMC4669223
ROM???
I tried the one from hddguru files the WD400BB-00JHC0-05.01C05-WD-WMAMA9132942 but still a sabre id
if anyone has this rom i would appreciate it if you can send it.
P.S. Original 25p10 chip is not working , i tried to read it with external programmer and it reads all ff.
thank you in advance
Users browsing this forum: Google [Bot] and 80 guests
