 Post subject: Western Digital SATA Drive wd1600AAJS
PostPosted: September 14th, 2009, 16:53
hello, i need some help
I have a western digital 160 GB hard drive (wd1600aajs) that after a power falure is no longer detectd in the system bios.
I have change the PCB with an identical drive, but still nothing ????
 Post subject: Re: Western Digital SATA Drive wd1600AAJS
PostPosted: September 14th, 2009, 17:33
This can be different problems.
Anyway, a simple pcb swap usually not solves problems, but makes more...
If you want your data, ask some pro near you for help.
If you want read, try this:
results-the-yourself-solutions-t11912.html
Janos
PostPosted: September 15th, 2009, 5:36
Specialist equipment is needed to maintain compatibility between the firmware on the HDD and the code in ROM of the PCB. Simply replacing PCB is useless. Professional help is needed.
Users browsing this forum: Google [Bot] and 332 guests
