 Post subject: maxtor 320 gb is not formatiing please help
PostPosted: September 16th, 2009, 5:31
i have a maxtor 320 gb internal hard drive that wont format when i try to use the windows boot cd i have tried to wipe the entire disk with a bootable cd called hdat and used the fdisk and it worked but when i try to format it takes to long and then stops , the chkdsk (before i did the fdisk ) didnt work, so now i have a partitioned disk thats unable to format.
is there a powerful tool to format and partition and check for bad sectors that works on ms-dos as a bootable cd , i hope u can help me with that poeple
 Post subject: Re: maxtor 320 gb is not formatiing please help
PostPosted: September 17th, 2009, 3:25
man, no one want to help , youre replying on other threads why dont you reply to mine??!!
PostPosted: September 17th, 2009, 3:37
Download MHDD and test the drives surface.
"man, no one want to help , youre replying on other threads why dont you reply to mine??!!"
Maybe you could try using better manners in your post?
Zero Alpha: zeroalpha.com.au
PostPosted: September 17th, 2009, 16:00
i have downloaded the tool and it cant continue the scan, it gives an error with the ("!") mark and stops the scan :( :( :(
its a new hdd is this thAT BAD ??
PostPosted: September 17th, 2009, 23:30
you have a FW problem you should send it to a PRO
If you want your data.
If not then buy another one
PostPosted: September 18th, 2009, 2:57
He doesn't want (most probably) data because he's trying to FORMAT the drive.
I vote for firmware problem. I think a pro is available in his area, don't know if any valuable member of this forum is (look at the members section and filter by location). If it is a FW problem it can be solved at reasonable price and drive can be used again, otherwise replace it.
Users browsing this forum: No registered users and 61 guests
