 Post subject: SV2042H - 20GB SAMSUNG PATA
PostPosted: September 16th, 2009, 7:09
Hi to all,
Have this disk Samsung SV2042H, that with the original PCB the disk don't spin.
i had a donor PCB the disk spin but get this in the terminal:
U H: +00000
H: +00001
H: +00002
H: +00003
H: +00000
H: +00001
also change the PCB from a SV4003H, and have also the same problem.
Have this disk too much adaptive info ?
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: SV2042H - 20GB SAMSUNG PATA
PostPosted: September 16th, 2009, 7:37
The PCB is the same for 1021, 2042 and so on (it's VG11+) but it is different code and maybe there's something else.
The SV4003 won't work.
Call me on MSN I'll guide you ;)
PostPosted: September 16th, 2009, 9:21
mith be the rom?
HddSurgery - Professional Data Recovery Tools
PostPosted: September 16th, 2009, 12:37
Thanks BlackST for the help :D
ZeBong
" Россия еще раз"
PostPosted: September 16th, 2009, 18:20
I vote for preamp.
The original PCB probably got overvoltage and preamp too.
Check preamp!
PostPosted: September 17th, 2009, 1:07
i would fix pcb, if not fuse then motor driver.
PostPosted: September 17th, 2009, 4:40
It's VG11+ !! You should know that this drives have..... [CENSORED] :mrgreen:
Users browsing this forum: Hardcore Games and 216 guests
