 Post subject: WD3200BMVS-11F9S0 FW ?
PostPosted: September 30th, 2009, 0:48
Hello friends,
please any one have this drive firmware
08.01A08
specially mod. # 0103
cannot read from the drive
the drive detected as WDC ROM MODEL-VENUS-
any help will be appreciated
thank you
 Post subject: Re: WD3200BMVS-11F9S0 FW ?
PostPosted: September 30th, 2009, 10:13
you cannot use 103 from different drive because it's unique
and also drive is not using it when it starts, so you don't need it
PostPosted: September 30th, 2009, 19:17
Hello Mr.Doomer
thanks for reply
first, i have SD ( hd doctor for wd ) when i have to write a ROM
I have first to backup five modules : 0102 - 0103 - 0105 - 0107 - 0109
when trying to write rom with this modules except 0103 the program shown that it cannot find mod.0103
and the original module 0103 is corrupted and can not be read from the drive
thank you
PostPosted: September 30th, 2009, 20:22
103 is adaptives copy
PostPosted: September 30th, 2009, 20:27
so how can I solve this problem to make the drive detected normally without this module ?
PostPosted: September 30th, 2009, 20:57
would you also like some money to be sent to you?
use your brain already
PostPosted: September 30th, 2009, 21:46
you right Mr.Doomer
thanks for help
i'm really appreciated
PostPosted: October 1st, 2009, 2:49
Problem solved with very simple way :wink:
thanks Mr.Doomer
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 293 guests
