 Post subject: Techno key error: Can't write ROM
PostPosted: October 7th, 2009, 7:16
Hello gurus,
I have been trying to use a donor PCB for a WD rom restoration by SA, which didn't work. Now I can't even write the original ROM back to it. The pcb will no longer spin any drives. Any solutions?
Techno mode key
Techno mode key:........................ : Techno key error unexpected error: Drive is not ready
ROM:
Flash Dir reading....................... : Module 0B reading error Data request error - Drive is not ready
ROM reading............................. : HDDs ROM reading error Data request error - Drive is not ready
Firmware version........................ : Module 0B reading error Data request error - Drive is not ready
HDD Readiness timeout (10000 ms)
HDDs RAM reading error - Drive is not ready
Write ROM
Techno mode key......................... : Techno key error unexpected error: Drive is not ready
Zero Alpha: zeroalpha.com.au
 Post subject: Re: Techno key error: Can't write ROM
PostPosted: October 7th, 2009, 9:07
What model?
PostPosted: October 7th, 2009, 10:21
PC3k UDMA or PCI ?
88i6745 MCU / ROYL family?
http://pcrecoveryllc.com
PostPosted: October 7th, 2009, 10:30
PCB is dead now. It's not coming ready anymore
PostPosted: October 7th, 2009, 16:20
a little funny note: :mrgreen:
Read Only Memory
PostPosted: October 7th, 2009, 16:33
Sounds like your ROM is corrupted..
PostPosted: October 7th, 2009, 17:12
yes, you have wrote in one corrupted rom content, and your drive no longer function even for rom recording.
PostPosted: October 7th, 2009, 20:20
UDMA pinnacle...
Its a shame thats its unrepairable. I'll RMA it :mrgreen:
PostPosted: October 15th, 2009, 15:52
It is probably repairable by patching the pcb with external flash memory preloaded with correct ROM image...
I also have one that failed writing and now it is bricked. I will try to patch once i have time
PostPosted: October 15th, 2009, 16:02
On maxtor DM9 works, but in WD....
I am doubt about it.
PostPosted: March 25th, 2024, 5:07
WOW, having the exact same issue
