 Post subject: Don`t want to format my HDD!!
PostPosted: October 12th, 2009, 12:39
Hi!
I`ve got a usb 2,0 HDD and when i plug it into my PC it says that I have to fomat the hard disk,
but I don`t want to because I`ve got over 200 gb on it!
If someone know what to do can you please help me?
Thanks in advance!
 Post subject: Re: Don`t want to format my HDD!!
PostPosted: October 12th, 2009, 13:02
Normally when I see this problem in repairing computer a person has disconnected his drive or usb incorrectly. This has caused this problem. Check your partition table and see if you can read it and if not repair it.
Try MHDD to help you to figure out what is your exact problem on this drive
Iorana Haraharaini
PostPosted: October 12th, 2009, 13:23
Ok, thanks for replying.
When I disconnected it i plugged it into my nintendo wii, and when I plugged it back to PC the message came up (You need to format your hard disk..).
By the way, I can`t find this program MHDD that is compatible with my pc which is 64bit system and not 32bit.
PostPosted: October 12th, 2009, 13:26
PostPosted: October 12th, 2009, 13:56
Your FS on the HDD is damaged.
You need to repair it ( = will loose a lot of files, but the hdd will be usable again) or recover the files.
If your data is important, ask for help the local data recovery company, this case is in cheap range if you select the good company.
But i suggest to make a sector copy from the drive BEFORE send it in to diagnose....
Janos
PostPosted: October 12th, 2009, 15:55
I gave up!
I formatted it and all is gone :(
But now it works.
Is there chance of getting back all my data??
PostPosted: October 12th, 2009, 16:22
it depends on the format methode, but surely less than before.
PostPosted: October 12th, 2009, 18:45
Try RStudio Raw recovery and see if you can find any of your data or Winhex can do raw recovery too on this one. All you had to do was fix your file system MBR on this one.
Iorana Haraharaini
Users browsing this forum: Google [Bot] and 229 guests
