 Post subject: Sagate 7200.9 ST3160812A Of unable To Of load Of overlay
PostPosted: April 29th, 2009, 15:44
P) PATA Of reset
Failed of sys of sect. write
Read Of ver Of retrys
Read Of ver Of falture!
Unable To Of load Of overlay 01|000A
I want to Recovery Data??
 Post subject: Re: Sagate 7200.9 ST3160812A Of unable To Of load Of overlay
PostPosted: April 29th, 2009, 21:38
There are some guys in China which probably can help you. If you willing to pay a lot I also can find a Russian guy in China who's a guru in DR
PostPosted: May 2nd, 2009, 0:21
Hi xsx007
we have many cases like yours
to recover data from this condition, you will have to perform head-swap
-BR-
PostPosted: May 3rd, 2009, 22:56
and need several Set of Donor Head
Спасибо
СУТИОНО / АПИНГ
PostPosted: October 15th, 2009, 13:33
Perhaps it's not necessary to do a head swap. By hyperterminal you can send some commands to Force to writte the sys sec.
PostPosted: October 15th, 2009, 16:00
I does not work in all of the cases. There could be a hardware cause of inability to write on H0.
In this case u cannot force writing. U can, but it won't do anything useful... :)
MHA replacement solves the problem in most of the cases when it is HW issue.
PostPosted: October 15th, 2009, 16:06
even if the hw problem in the pcb? :P
PostPosted: October 15th, 2009, 17:35
I said 'most of the cases'.
In most of the cases the cause is not the pcb. At least I never met a PCB that prevented writing, but I met several cases when the MHA caused such problem.
PostPosted: October 15th, 2009, 17:58
you are right.
I haven't seen this too.
Only i can imagine the situation, but only in the extreme category.
Janos
PostPosted: October 15th, 2009, 18:22
thx for agreeing :D
Users browsing this forum: No registered users and 75 guests
