 Post subject: Seagate 500gb Barracuda 7200.11 ST3500320AS SD15
PostPosted: October 8th, 2009, 12:26
I've purchased a ST3500320AS.
The problem is the motor spin-up don't work. Anybody knows if I can change the controller card ?
I have found the same HD but the formware was updated to SD1A...
Can I switch the two controllers cards ?
Sorry for my bad english... :)
Thanks !
 Post subject: Re: Seagate 500gb Barracuda 7200.11 ST3500320AS SD15
PostPosted: October 8th, 2009, 12:33
No you can't switch the cards, not without swapping the ROM too anyway.
PostPosted: October 8th, 2009, 13:10
I bet your board is fine and you have another problem.
This topic was discussed on this forum a lot.
Use search option.
www.datarecoveryne.com
PostPosted: October 8th, 2009, 14:56
some little addition:
The updated (SD1A) firmware is not in the "card", but in the platters, hidden on factory tracks. ;)
Janos
PostPosted: October 11th, 2009, 5:49
Use search option.
I'm not english and I don't know for what I have to look...
PostPosted: October 11th, 2009, 13:12
Did you drop it?
http://www.datasaversllc.com
PostPosted: October 16th, 2009, 13:48
No..
PostPosted: October 16th, 2009, 19:43
hi,
yeah. you can swap two PCB if it same model. but you had to swap ROM chip too
data recovery service[/b]
PostPosted: November 3rd, 2009, 16:28
How I can do it ?
PostPosted: November 3rd, 2009, 17:16
By desoldering the ROM from your drives PCB and soldering it in place to the donor's PCB.
But as you ask this, this job may be miles beyond your scope.
As others already wrote, you may have other problems, ranging from firmware faults to spindle seizure.
Users browsing this forum: No registered users and 140 guests
