 Post subject: ST3120023A PCB help -
PostPosted: October 16th, 2009, 12:41
I have a
Seagate ST3120023A tha will not spin up
PN: 9w4001-301
Firmware 3.33
I could not find an exact match on the PCB for this drive but I do have
Seagate ST3120023A
PN: 9w4001-001
Firmware 3.30
I put this PCB on the bad drive and it spins up - but I can't get a PC to recognize the drive...
Can I fix the power interruption on the bad PCB?
Is there anything I can do to the working PCB to make it compatible with the drive?
There was a western digiatal in the same computer - same symptoms - I repaced the PCB on it with an exact match and everything worked like a charm....
Anyway - does anybody have any suggestions?
Does anybody know where I can find an exact PCB match for this drive?
Thanks for the help
 Post subject: Re: ST3120023A PCB help -
PostPosted: October 16th, 2009, 19:39
as you said.. i don't think it PCB problem.
data recovery service[/b]
PostPosted: October 16th, 2009, 19:48
1-you must transfer the ROM on the bad PCB to the matched PCB, you have to post a photo of your original PCB to let us show you the correct IC to transfer
2-If the data is very important then you have to send it to a pro
PostPosted: October 18th, 2009, 11:35
Here is a photo of the bad pcb - thanks for the help on this
File comment: Pic of bad PCB
PostPosted: October 21st, 2009, 21:19
Sorry - I accidently opened two posts on this topic...
Please use this thread
seagate-st3120023a-pcb-firmware-power-problems-t13666.html#p89461
Users browsing this forum: Google [Bot] and 227 guests
