 Post subject: Random errors, when using HDD
PostPosted: October 11th, 2009, 5:43
I've got a problem with my HDD. I've bought it few month ago, but now, when i start my usual desktop(Xubuntu), it works very slow, and writes lots of errors to console. When i start failure recovery session(that means, no autostart applications) it works rather good. I think, it is some region-dependent error, that appears when some application uses data in broken region on HDD. I am attaching HDD SMART error log. Can somebody explain, what the problem is, and what can i do to fix it?
File comment: HDD SMART error log
ST3160023A-2009-10-11.txt [8.69 KiB]
Downloaded 497 times
 Post subject: Re: Random errors, when using HDD
PostPosted: October 11th, 2009, 6:43
Scan the drive with mhdd and post that log.
Zero Alpha: zeroalpha.com.au
PostPosted: October 18th, 2009, 12:43
Here it is.
File comment: MHDD log
mhdd.log [19.2 KiB]
Downloaded 502 times
PostPosted: October 18th, 2009, 13:10
The drive has bad and/or weak sectors.
It is failing and should be replaced immediately.
PostPosted: October 19th, 2009, 6:47
Very bad... I've bought it not so far ago.
PostPosted: October 19th, 2009, 7:13
RMA it and take a print out of that log with you.
PostPosted: October 20th, 2009, 14:28
I'll try, but first i need to find its receipt from shop. Is it possible, that HDD got broken, because i haven't fixed it in my system block? It was because i ran out of space there.
Users browsing this forum: Google [Bot] and 244 guests
