 Post subject: SANSUNG HD161HJ/SRO REV A
PostPosted: October 21st, 2009, 8:49
Hello I have this in a terminal HD sansung suggestions are welcome
SPW 0000 NoLk
5V: 04688
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0005
DAC: 808B
UF 2 BrkFsamErr
UF 3 GryDetectErr
H: +00001
SK C: 0001D6E8
ENG>SRV> AP_FSAM
C: 00003B52 H: +00000
SR : +00000
UF 7 1stGrayErr
UF 3 GryDetectErr
H: +00001
SK C: 00013761
AP_FSAM
SR : +00001
UF 7 1stGrayErr
UF 3 GryDetectErr
H: +00001
SK C: 0001534B
AP_FSAM
SR : +00002
H: +00000
UF 2 BrkFsamErr
UF 3 GryDetectErr
H: +00001
SK C: 0001E049
AP_FSAM
SR : +00003
UF 7 1stGrayErr
UF 3 GryDetectErr
H: +00001
SK C: 000154F6
AP_FSAM
H: +00000
UF 2 BrkFsamErr
UF 3 GryDetectErr
H: +00001
SK C: 0001E28A
 Post subject: Re: SANSUNG HD161HJ/SRO REV A
PostPosted: October 21st, 2009, 11:16
First thought goes to heads...
PostPosted: October 21st, 2009, 12:03
It is definitely not able to reach track following. It can't even properly catch servo.
90% chance of heads is my guess....the other 10% is left for strange occurences. heh.
PostPosted: October 21st, 2009, 13:06
In fact . No servo, no TF, and Gray Err.... Heads, or a bad PCB (the read channel completely KO with everything else OK) or something weird....
PostPosted: October 21st, 2009, 13:15
This was my guess as well, the other 10% i spoke of includes read channel KO.
I would assume that this drive is clicking, probably want to try the PCB on another drive and see if it clicks in same pattern.
On samsungs it also shouldn't hurt to try a known good PCB on the bad drive, and see if you get the same clicking/terminal output.
PostPosted: October 21st, 2009, 15:00
He begins by clicking the exit of the terminal, I imagine that is also head, I make the switch and put the result after, thanks to all
PostPosted: October 21st, 2009, 15:51
Hi
GryDetectErr
H: +00001
means head gone. 95%, 5% PCB
DF :)
DF :)
www.datatracksystem.net
PostPosted: October 21st, 2009, 18:00
hi,
it got head damage
data recovery service[/b]
PostPosted: October 22nd, 2009, 16:53
Can you open it and try to see the head 0 at the microscope.
Maybe head is dirty, and can not read the SA.
ZeBong
" Россия еще раз"
PostPosted: October 23rd, 2009, 11:15
I made the exchange of reading heads successfully, problem solved thanks to all the opinions
Users browsing this forum: Majestic-12 [Bot], michael chiklis, MindMergepk and 119 guests
