 Post subject: WD2500 will not spin
PostPosted: October 19th, 2009, 16:43
I'm think about replacing the PCB board but I'm not sure if this will get it spinning again.
the board does not appear to have electrical blow outs nor does it smell like it.
Does anyone know if this will be a waste of my time?
I've also been reading about having to transfer a ROM chip from the old PCB to the new one. any info on that would be appreciated.
Rizznut
 Post subject: Re: WD2500 will not spin
PostPosted: October 19th, 2009, 19:04
You can try it.
Zero Alpha: zeroalpha.com.au
Find Cheap Donor Drives App: https://www.zeroalpha.com.au/donor-drive-app Updated February 2026
PostPosted: October 19th, 2009, 19:20
If it is only your pcb board causing you this problem it might be cheaper for you to find someone to change it out for you. This should not be expensive for you and should be an easy recovery if you do not do anything to this drive.
Iorana Haraharaini
PostPosted: October 20th, 2009, 1:39
You can try the PCB swap, more than likely the simple swap will not work, but your drive should spin up if the PCb was the cause.
PostPosted: October 20th, 2009, 5:01
yeah. you can try. some time just PCB have problem.
data recovery service[/b]
PostPosted: October 21st, 2009, 20:00
Swapping the PCB is the easy part. I'm concerned about the ROM chip. I've never removed and re-attached a chip.
Users browsing this forum: No registered users and 211 guests
