 Post subject: RE's in the house... need some help with Hitachi SLA 360
PostPosted: October 26th, 2009, 16:40
Hello to all,
Here is the situation:
I have a HDT721010SLA360 drive on which I need to clear smart and take care of the G-List.
The model is currently not supported by SD and I am not sure if it's supported by Ace.
My approach:
Since i could not find any updates released for this drive series yet, my approach was to sniff out usb traffic on SD from some other Hitachi drives KLA360 and some other models and hope that one has compatible commands. Unfortunately I have not had much luck because of the fact that SD's HD Doctor uses USB to communicate with the back-end PC,(on which I can see the interrupts) but I can't see the real front-end juice, which Is what I need. Yes, I have made a logical thinking error on this since I did not consider the fact that I am capturing at the wrong layer or better yet the wrong interface.
Questions
    Does Hitachi change ATA commands for clearing smart and G-List often or are they pretty much the same on most models?
    Is this model currently supported by Ace?
    Does anyone have experience with RE on SD?
    Does anyone have any tips or ideas on how to intercept commands from SD?
    Anyone willing to share or exchange?
    Does anyone have the same issue and would like to collaborate on this?
Thanks as always for putting your minds to work :D
 Post subject: Re: RE's in the house... need some help with Hitachi SLA 360
PostPosted: October 27th, 2009, 4:41
I have UDMA and it is not supporting this drive (yet).
This drive has new techno commands, so it is not compatible with any other model supported.
Since i have no free time i'm waiting for ace to come up with the solution.
Should still be a few months though.
If however, we could cooperate to find a solution ourselves, i would be very glad indeed.
Dobre
Murphy was an optimist
PostPosted: October 27th, 2009, 5:31
Read the HGST manual. SMART Attribute Initialize doesn't need special mode AFAIK
PostPosted: October 27th, 2009, 5:42
Yes, but my drive has problems with SA, not smart :(
Dobre
PostPosted: October 27th, 2009, 18:31
Ah in that case find the 48bit super on
Simples :roll:
PostPosted: October 27th, 2009, 18:32
Cooperation best kept to the other forum ;o)
PostPosted: October 28th, 2009, 11:30
Are you referring to disable SMART? If so yes this can be done via DFT, but how about clearing SMART? And of course my main issue is that G-list is full.
PostPosted: October 28th, 2009, 11:32
Has anyone seen any vendor update for the drive series?
PostPosted: October 28th, 2009, 12:16
quasimodo :-
If you need get rid of G-List download the manual for that drive and read it......
PostPosted: October 28th, 2009, 14:46
guru wrote:
quasimodo :-
:good: The manual is great!!!
I definitely am finding use for it. However I did not see any reference to the growing defect list. Is is one of the vendor logs... maybe downloading all the vendor logs and analyzing them to find the g-list and overwrite it... could this be a step in to the right direction?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 245 guests
