 Post subject: does everyone encounter this??
PostPosted: October 27th, 2009, 5:22
i have a 3pcs hdd that cannot format and when you break the partition and create a new one it reverts from its original os.. i mean the drive has os and when you want to format it doesnt accept or says that unable to format.. the problem there is IT REVERTS to its original os although i destoryed the partition..
what should i do?? please help.. thanks..
 Post subject: Re: does everyone encounter this??
PostPosted: October 27th, 2009, 8:52
The key question is, what do you want exactly? :D
PostPosted: October 27th, 2009, 20:34
i want to format the drive.. to use it in other pc..
PostPosted: October 27th, 2009, 20:37
You either have a problem with your 3 computers or there is a problem with a drive.
www.datarecoveryne.com
PostPosted: October 27th, 2009, 20:59
there's no problem with my computers because i brought a drive for it and it works correctly..
what should i do with the drive??
PostPosted: October 28th, 2009, 3:05
If your computers are all OK, than RMA the drive, and will get a working one. :D
PostPosted: October 29th, 2009, 20:21
what rma stands for??
PostPosted: October 29th, 2009, 20:33
warranty
PostPosted: October 29th, 2009, 20:36
is there a possible way to repair my drive??
PostPosted: October 29th, 2009, 21:05
what's your drive model ?
Maxtor diamond max plus 9 ?
PostPosted: October 29th, 2009, 21:21
seagate barracuda.. 80gb sata and 2pcs 80gb ide..
they have the same problem..
PostPosted: November 18th, 2009, 20:41
does anyone can help me with this??
PostPosted: November 19th, 2009, 3:35
Did you find out your answer?
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: November 25th, 2009, 20:21
not yet.. =(
Users browsing this forum: Google [Bot] and 264 guests
