Forum rules
 Post subject: Can dirty power supply cause bad sectors
PostPosted: October 30th, 2009, 18:49
That pretty much sums up the question : Can a bad PSU cause bad sectors on hard disk, or do hard disks have sufficent circuit protection to stop this?
I ask because a friend has replace his hard disk twice in as many weeks and it keeps developing bad sectors. He swears black and blue that he has not knocked it or otherwise mishandled it.
TIA
-Al
PS: 4.v on 5v rail and 12.46v on 12v rail into HDD in question, both fall within +/- %5.
 Post subject: Re: Can dirty power supply cause bad sectors
PostPosted: October 30th, 2009, 20:53
1. you can check PSU quality only with oscilloscope.
Forget the DMM.
2. yes, can cause!
Especially the voltage noise, unstability.
But most common case the PCB or preamp burnout.
Can cause SA corruption as well.
3. in case of your friend, i would replace the cable and connector wich goes to this hdd, if have anything between the PSU and HDD.
4. This is not an option for you, because i have only this unit for protecting hdds. :D
Janos
PostPosted: October 30th, 2009, 21:00
Forget the DMM.
2. yes, can cause!
Janos
Thanks for the reply.
I just dont quite understand what you are refering to in point 4? Is it something to do with a special unit that you put between Molex connector and HDD?
Cheers
-Al
PS: I have a scope so I will hook it up and see what sort of noise is there.
PostPosted: October 30th, 2009, 21:40
bigal.nz wrote:
Forget the DMM.
2. yes, can cause!
Janos
Cheers
-Al
I have one protection unit wich is good for protecting the hdd from all the harm things can come from the PSU.
I have designed it, and i sell these in Hungary.
If you want one, you can PM me.
Janos
PostPosted: October 31st, 2009, 21:51
Forget the DMM.
Janos
Hi Janos,
I have attached two images of the 12v and 5v rails by back probing the molex with the scope.
What do you think? Looks bad? Settings for both pics was :
5mV/div (but 10x probe - so 0.005 x 10 = 0.05v/div)
.5ms
I should connect a spare Enermax I have here and compare....
Cheers
-Al
File comment: 12v
File comment: 5v
PostPosted: November 1st, 2009, 6:11
um, this is not a good measure methode.
A capture scope can be better, because the idle computer not makes current spikes...
Anyway, this looks noisy anyway. :D
Janos
PostPosted: November 1st, 2009, 7:18
You need to look at single traces of two or three cycles.
Then look at the trace, it should look something like a square waveform.
https://www.mjm.co.uk/
PostPosted: November 1st, 2009, 14:07
Ok well I am keen to try again with a better technique, but might need some more information.
1) Is it ok to use not the molex that goes into the HDD but another molex on the same wire chain?
2) When you say lookat it over 2/3 cycles I assume I needto zoom in on the time quite a bit?
3) GND to GND of molex?
Al
PostPosted: November 1st, 2009, 14:09
Janos
So your saying that I am looking for intermittent spikes, (in addition to a dirty waveform).
Wonder if I could do ith using triggering?
-AL
PostPosted: November 1st, 2009, 15:04
Janos
-AL
Yes, you can catch it using trigger.
Set up trigger level in 5V line to 5.4V (+400 mV) than 4.8V (-200 mV).
When measuring, do something on the PC.
Like boot up to windows, and start some programs.
It would be interesting if you try to write a DVD when measuring. :)
Let me know what was the result. :)
Janos
PostPosted: November 1st, 2009, 23:32
Ok I have had another crack at it. Some pics are time/div zoomed to 5us. Some are 1ms. (check file names)
Both are heavily zoomed on v/div to 5mv (but thats a 10x probe so its really only 0.05v/div).
This was not with a load (or hdd) attached to the molex.
The old PSU picture certainly has some spikes in it (they are a bit faint in the photo).
I assume these spikes are the bad things, though in reality the biggest spike was 4 divisions, so only 0.02v....
Thoughts?
Cheers
-Al
File comment: 5v rail
New PSU
Time/Div = 1ms
Volt/Div = 0.05
This was as close as I could get to making it display anything near a squareish wave?
New PSU
Time/Div = 1us
Volt/Div = 0.05
Old PSU
Time/Div = 1ms
Volt/Div = 0.05
Old PSU
Time/Div = 1us
Volt/Div = 0.05
Those spikes go all the way to the top of the screen - just.
