 Post subject: helping with recovering formated data
PostPosted: October 31st, 2009, 23:03
i will make long story short, i just formated my old hard disk with all the important data and installed windows over it.
i really don't know what to do!!!
right away after i finished to install windows i discoverd the mistake!
there is a way to restore evertying?
some details:
the old version that was installed on the HD was XP Pro and the current is XP Home editon.
the HD hat two partitions C and D, now there is only C.
i chose the Quick NTFS formmating option.
HEELLPPP i don't know what to do!!!
thanks
Amit
 Post subject: Re: helping with recovering formated data
PostPosted: October 31st, 2009, 23:41
Put a different hard drive, install OS. Image your formatted hard drive to another drive. Then connect imaged drive to the OS and run some logical file recovery software!!! You should be able to get some if not all.
PostPosted: November 1st, 2009, 0:03
Agree. Image this drive do now work on this hdd. Then you can use RStudio or another program to search the image you have made. This should get back most of your data on here.
Iorana Haraharaini
PostPosted: November 1st, 2009, 0:13
how to image the drive?
PostPosted: November 1st, 2009, 1:53
RStudio will do this one for you there is also a number of other imaging software out on the market. RStudio also has another software called R-Image. Check this one out might help you to image this drive after image Rstudio can do recovery on your files.
Iorana Haraharaini
Users browsing this forum: ccc and 242 guests
