 Post subject: SD Flash Doctor - Anyone used it?
PostPosted: September 3rd, 2009, 16:18
Please, no replies from Ace Labs or SD!
 Post subject: Re: SD Flash Doctor - Anyone used it?
PostPosted: September 3rd, 2009, 18:09
dont use it
ZeBong
" Россия еще раз"
PostPosted: September 3rd, 2009, 18:25
You're saying you don't use it or recommending that one shouldn't use it?
PostPosted: September 8th, 2009, 9:26
I have not used, but have been told it is still in early beta stages. Some useful information on Salvation Data Blog regarding it.
Still a little hesitant about it though. Would be very interesting to hear from anyone who does have it though.
PostPosted: September 15th, 2009, 3:31
SD has released its new version flash 3.0, if you are interestedin it, may go to its website have a look.
PostPosted: September 15th, 2009, 5:37
This version is only in chinese?
PostPosted: September 15th, 2009, 8:17
hi
i downloaded the 1.30 in englsh, they added other page structures
Bye
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: September 16th, 2009, 15:57
[quote=\"irs\"]hi
Bye[/quote]
hi ,
Have you Managed To Recover Data From Anything Till Today with the tool ? .
PostPosted: September 22nd, 2009, 1:11
hi amarbir,yes i recovered through sd flash
PostPosted: November 2nd, 2009, 7:48
would be interested to see what others are saying about sd flash.
PostPosted: November 16th, 2009, 3:45
Anyone?
PostPosted: December 22nd, 2009, 23:09
well, I am using SD flash, it's not bad according to its price. usually there's 40% around success rate for tsop48 chips, for sandisk chips, sd flash doctor supports only some capacities of 128mb, 256mb, very small capacities; you need very carefully put the chip well in the card reader. for some old chips, you need to clean the pins and try, I often tried several times to put the chip and you may get different results to recognize the chip info. Their engineer recommend to use winhex to analyse the data structure and then choose the data combination method they provide in the flash doctor, this is to improve the efficiency of the recovery process. I will update my experience when I get more tricks there...
Train yourself before you step into DR
Users browsing this forum: Google [Bot], Google Feedfetcher and 72 guests
