 Post subject: SV4002H
PostPosted: November 6th, 2009, 13:49
Hello I have a hard disk sansung SV4002H, it connects normally without clicks, only with a sharp noise of your engine, the terminal have only this, any suggestions are welcome
UCalib Done
ENG>
 Post subject: Re: SV4002H
PostPosted: November 6th, 2009, 14:12
and?
What is the problem?
Janos
PostPosted: November 6th, 2009, 16:13
If you try to idenitfy it with MHDD what happens ?
PostPosted: November 7th, 2009, 7:37
He simply does not detect the disk normally turns into a state of readiness as if it were functioning normally, MHDD does not detect single detail is what gets a sharp noise like engine bearings were spending
PostPosted: November 7th, 2009, 9:02
I vote for something else like headcrash (didn't hear that noise...). Did you open it ?
PostPosted: November 7th, 2009, 9:56
He did not want to open it I'm still trying to identify the problem first, and also I am looking for a donor, so I would check all the options for possible defects, now thanks for help
PostPosted: November 7th, 2009, 14:19
In this situation it is impossible to identify exactly the problem. I would use a different approach but this involves use of a DDA and other instruments and also work with specific commands but I cannot disclose it, sadly.
If things were more evident, maybe you could get a little more help. Later we will see (when accepted and maybe having a donor at hand).
Users browsing this forum: pepe, skinbob and 96 guests
