 Post subject: Need WD1600BB-00GUA0 DCM: DSBHCTJAH PCB: 2061-001266-100 AC
PostPosted: November 11th, 2009, 18:49
Does anyone has it ??
I have changed the pcb with this one :
WD1600BB-00GUA0 DCM: DSCHNTJAH PCB: 2061-001265-200 AK
I made some irreparable mistake?
because i searched for a drive with only this spec : WD1600BB-00GUA0 without worryng about DCM and number on the pcb ??
The hd now awake , but the system operator not recognize it ... before changing the pcb the hd not awake , did nothing
I have still the chance to recover my data ??? ( all digital photos from 2000 until the last summer !!!!!!!! :(( )
Thanks a lot !!!!
Bye from italy... ( and sorry for my english .. )
 Post subject: Re: Need WD1600BB-00GUA0 DCM: DSBHCTJAH PCB: 2061-001266-100 AC
PostPosted: November 11th, 2009, 19:07
Thanks a lot !!!!
i forgot the date :
DATE :13 SEP 2004 ..
Thanks again ...
PostPosted: November 11th, 2009, 19:13
You will need to change the ROM.
ZeBong
" Россия еще раз"
PostPosted: November 11th, 2009, 19:19
before changing the pcb , no sign ... the drive do nothing ...
now with the "new" pcb it start , xp recognise it with " Found 160WD Drive ecc ecc " .. but i cannot see in the drive list ... and also with partition magic i cannot see it .... :(
PostPosted: November 11th, 2009, 19:23
you need to check the head map.
ZeBong
" Россия еще раз"
PostPosted: November 11th, 2009, 19:27
and to check the head map what i have to do ?? im not so expert ..
thanks...
PostPosted: November 11th, 2009, 21:22
www.datarecoveryne.com
PostPosted: November 12th, 2009, 9:22
so what i have to do ?? send the hd to a specialized company ?? :?
PostPosted: November 12th, 2009, 11:33
Yes, you should contact blackst here in the forum, and he is a guru from italy.
ZeBong
" Россия еще раз"
PostPosted: November 12th, 2009, 14:26
thank you zebong ... i will write to him ...
I will keep informed ...
Thanks again ..
PostPosted: November 12th, 2009, 19:10
hi,
first are sure is same PCB?
second have you change ROM chip? it position is U12. it should be 8 pin chip. you can find out locate repair to swap it if you can't handle it. that drive will be fine if just PCB problem. 8)
data recovery service[/b]
