Forum rules
 Post subject: CE-ATA Adapter
PostPosted: January 15th, 2009, 11:06
Does anyone know where to buy a CE-ATA adapter?
thanks!
G
 Post subject: Re: CE-ATA Adapter
PostPosted: January 15th, 2009, 11:33
http://cgi.ebay.co.uk/1.8%22CE%2FZIF-ha ... 7001r14584
http://www.soarland.com/ZIF_CE_1.8_Inch ... t-253.html
http://www.soarland.com/ZIF_CE_1.8_Inch ... t-213.html
http://www.span.com/catalog/product_inf ... ide_right1
Guru..Don't you feel, that sometimes you become a bit over "To The Point"?
Or is it something, the native language of "Cosmos"? :)
I just hate spammers...It was a Spammer, who ruined my life!
PostPosted: January 15th, 2009, 12:46
Should have been more specific.
I need to find a supply of 1.8" CE-ATA ZIF (CE-ATA) connectors. For specs goto http://www.ce-ata.org/specifications.asp
I'm not looking for CF+ 1.8" ZIF which was kindly linked to
I have also attached a picture if you cannot understand my cosmos speech ;o)
PostPosted: January 16th, 2009, 4:46
We get ours from esskabel.de, but we also use USB enclosures for ZIF too.
PostPosted: January 18th, 2009, 5:25
Does anyone know what this is? I guess know one has a scobby do!
PostPosted: January 18th, 2009, 11:39
This is ZIF connector
it has different type for different drives (but some drives have similar connector, like Toshiba and Hitachi)
I know two types of ZIF connectors and I have both adapters, just google it and you will find what you are looking for
PS: it might be also regular CF pin-connector (like on 1" drives) but it is hard to see from your picture. If so you would need third type of adapter
PostPosted: January 19th, 2009, 10:23
Kasmar!
Ok know one knows....
I will keep searching. I have all of the other adapters and converters. As this is a new interface spec I guess it will take time before a suitable product is ready :O(
PostPosted: January 20th, 2009, 5:00
What unit did this HDD come from?
PostPosted: January 23rd, 2009, 19:52
Hi Guru,
I use this one, and it works very good.
http://www.span.com/catalog/product_inf ... ts_id=8932
Best Regards
Bosse
http://www.rescue-it.se
PostPosted: January 24th, 2009, 5:14
"Mr Spokk, the women on your planet are logical. That's the only planet in the galaxy that can make that claim."
Still wrong connector :O) The CE_ATA uses MMC electrical schema, it's not ATA interface (PATA/PATA)
PostPosted: January 24th, 2009, 6:37
"He he so true, unfortunately logical woman are'nt so exciting, as they are...logical :lol:"
Okey then it's the same standard that Hitachi 1" drives use.
I had one of those 1" microdrives in and to fix that one I bought a Usb 8Gb hdd and took it appart and used that interface, not optimal to work via the Usb interface as I rather had worked with the ATA interface...but it did it's purpouse :)
Bosse
PostPosted: November 12th, 2009, 9:11
Dear Bosse,
could you put the detailes of the Usb 8Gb hdd, you bought' and took apart?
I am trying to do the same
Thank You
Haim
PostPosted: November 12th, 2009, 20:17
Hi Guru,
I'm also looking for the same adapter now (the small zif type). Any luck finding one? It seems others here don't really understand the difference, the adapter you need uses a smaller cable than a standard ZIF connector.
PostPosted: November 15th, 2009, 7:55
mr_spokk,
Dear Bosse,
Thank You
Haim
PostPosted: November 15th, 2009, 8:36
Hi, and sorry for the delay.
The drive I repaired was a Hitachi HMS361008M5CE00 Microdrive.
I bought one of those:
http://www2.computeruniverse.net/produc ... -black.asp
And then I took the usb-drive apart and use that connector as an interface.
PostPosted: November 18th, 2009, 13:49
i am holding in my hand the same HDD in the picture, it is from my 160GB ipod. the connector inside was it a ribbon cable converting the ce-ata to a standard ZIF HDD interface. because of the largesize i am worried the controler inside will not recognize the drive.
Users browsing this forum: No registered users and 6 guests
