 Post subject: Opening a compact flash
PostPosted: November 13th, 2009, 14:43
I've got a 6gb Seagate ST1 compact flash drive, where it appears the heads are seized to the platter. I don't work with many of these drives. I was just curious what you recommend for opening them. It looks like a tri-wing screw. Can you tell me the size, so I can try and locate one please? Thanks.
 Post subject: Re: Opening a compact flash
PostPosted: November 13th, 2009, 15:41
You won't find a tri-wing commercially that's small enough.
I posted recently that the best way is to use a sharp blade or scalpel. Crude but effective. Watch those valuable DR fingers!
Data Recovery Ireland
PostPosted: November 13th, 2009, 15:46
Yeah , i the one who used that sugestion , and look ma all fingers present =)) 2 drives restored to life in 1 day , both with stuck heads. Used a sharp scalpel on the tri wings.
PostPosted: November 13th, 2009, 16:36
Yep, agree.
The only way I could open them is with a scapel blade point.
PostPosted: November 13th, 2009, 17:10
Thanks for the suggestions. Now all I gotta do is try and find a scalpel. :lol:
PostPosted: November 13th, 2009, 17:14
One more question. Do you know what size scalpel you're using? I've seen #4, #10, #22, dental scalpels, etc.
PostPosted: November 13th, 2009, 17:34
I've used a number of regular 'stanley' blade style tools - it doesn't need to be anything terribly fancy.
I apply pressure to the centre of the tri-wing with the point of the blade and 'turn' the drive around the blade, rather than trying to turn the actual screw itself.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 236 guests
