 Post subject: Seagate 120GB ST3120026A
PostPosted: November 17th, 2009, 7:33
I have a Seagate ST3120026A, 120GB, F3.01. One of the components is burnt and lost. I am looking to replace it if I can identify it.
Help to define
thanks
File comment: Seagate ST3120026A
 Post subject: Re: Seagate 120GB ST3120026A
PostPosted: November 17th, 2009, 8:39
Sure that one is burnt ? Its a ceramic capacitor.
If you remove it and measure with an ohm-meter, you should get infinite resistance. Then its ok.
If it measures as short, just removing it will probably also solve the case.
Dobre
Murphy was an optimist
PostPosted: November 17th, 2009, 10:28
Thanks.
But I have lost it. I do not know face value.
PostPosted: November 17th, 2009, 10:39
The problem is elsewhere. Your drive most likely doesn't spin up. Am I right or should I re-orient the dish connected to my crystal ball ? :mrgreen:
PostPosted: November 17th, 2009, 10:48
BlackST
Not be the bore
On a disk of a photo of the favourite mother-in-law
PostPosted: November 17th, 2009, 10:52
You didn't get what I said :
the capacitor by itself if BURNT and on its place would most probably make the drive NOT to spin if shorted.
If you removed or lost it (when burnt) there is no short BUT this would not prevent the drive to spin up.
If drive still doesn't spin (working or not) , the problem is absolutely elsewhere.
If drive spin and clicks or doesn't ID, the problem is different.
PostPosted: November 17th, 2009, 10:56
Thanks!
Now I will check up :arrow:
PostPosted: November 18th, 2009, 2:43
The disk rotates, I feel vibration. :)
The disk in BIOS is not defined. :(
PostPosted: November 18th, 2009, 3:52
We need terminal report to know more.
Search this forum on how to do that.
Dobre
PostPosted: November 18th, 2009, 4:02
hi,
so it may PCB problem. you can take similar one from others PCB for replacement. it make be not only PCB have problem if still no work. may be firmware have problem also.
data recovery service[/b]
PostPosted: November 18th, 2009, 4:27
I will try to put other controller.
Disk old :(
