Forum rules
Clean Cabinete ? What you prefer ?
- Vertical 52%  52%  [ 12 ]
- Horizontal 48%  48%  [ 11 ]
Total votes : 23
 Post subject: Laminar Flow Clean Benches
PostPosted: November 19th, 2009, 18:58
Hi ,
Would like to see how is the most used "air" :)
Vertical or Horizontal
Please dont forget to vote
Regards.
ZeBong
" Россия еще раз"
 Post subject: Re: Laminar Flow Clean Benches
PostPosted: November 19th, 2009, 23:11
I guess in order to "prefer" you have to try both for a while which I don't think many people tried
PostPosted: November 20th, 2009, 16:03
I prefer diagonal. :D
PostPosted: November 30th, 2009, 14:57
Find some pictures.
VERTICAL
HORIZONTAL
ZeBong
" Россия еще раз"
PostPosted: November 30th, 2009, 18:29
We use Vertical Flow Hoods inside a Class 100 rated enclosure which uses vertical air flow units. Best of both worlds! :)
Data Recovery Ireland
PostPosted: November 30th, 2009, 18:44
There's probably a dozen laptop filters that got sucked into my horizontal Baker flow hood. I hate it when that happens...Anyone have that problem with a vertical unit?
PostPosted: November 30th, 2009, 19:10
Hmm
I don't even have this with horizontal unit
I'm not really sure how it can be, air blows INSIDE the bench it doesn't have suck
PostPosted: November 30th, 2009, 19:19
Baker Edgegard units.
PostPosted: November 30th, 2009, 20:59
I have a Horizontal flow bench and have had no problems.
PostPosted: November 30th, 2009, 21:02
I have a vertical Class100 , it works well and loving it.
PostPosted: December 4th, 2009, 18:37
Doomer wrote:
Hmm
We have two 4' Baker Edgegard units and one smaller Baker (setup for 1.8" and 2.5" only) which are horizontal as well as a Terra Universal VLF. I know what you mean about the Baker units. They have slots along both sides and the front bottom which are intake. There is the normal intake with prefilter above or below the unit as well. I think the primary advantage of this is if you are working with volatile chemicals, soldering, or any situation in which there are vapors, smoke, etc. Because with this setup, you do NOT get the particles in your face or room ,etc. Rather the air flow is VERY smooth and laminar towards the EDGES of the unit, hence the name.
Yesterday I did a head swap on a 1.8" Samsung HS08XJF. The suction is such that the actuator latch (so very small and light) actually became sucked approximately 12 cm or so inside!
Usually, I wipe my work area with a presaturated cleanroom wiper and lay in in front of that area before I begin my work.
I do love my Terra Universal unit, and though I was skeptical of the downward pressure it excerts at maximum flow, I lower it before I work on any drives.
Lastly, I am using these inside of a larger class 100 room, so this is simply overkill.
http://pcrecoveryllc.com
PostPosted: December 4th, 2009, 20:01
But it's not clean bench
It's induced draft
It sucks dust inside working area
PostPosted: December 4th, 2009, 20:27
Here's the unit we have...it's inside a hardwall Class 100 room besides.
http://www.bakerco.com/products/edgegard/
PostPosted: December 4th, 2009, 21:20
Actually it prevents pockets of vacuum around the edges or dust from getting in which would contaminate the working area.
