 Post subject: Hitachi 7250 series PCB swap - NVRAM issues?
PostPosted: November 21st, 2009, 5:13
Hi there,
I have a 3.5" Hitachi Deskstar 7250 series. The patient drive came in with a non-working PCB, which failed after a power surge in the customer's hosue. Fortunately I was also given an exact match donor drive which was bought at the same time.
I am using Salvation tools, which unfortunately do not support 7250 series (yet?!).
When I swap over the PCB directly I get clicking and the device stays busy, suggesting either there is an NVRAM mismatch, or the head assembly has failed. If I hot swap the PCB then the device becomes ready (suggesting HA is OK), but the LBA values are unreadable (I get a lot of 'FF'). Ordinarily I would attempt to regenerate the NVRAM however this option is not available to me for this series drive. Is there another way around this issue?
All the best,
John
0161 408 4857
 Post subject: Re: Hitachi 7250 series PCB swap - NVRAM issues?
PostPosted: November 21st, 2009, 5:23
Oh yes, what I presume is the NVRAM chip is at U7 on this revision of PCB.....
0161 408 4857
PostPosted: November 21st, 2009, 6:33
Have you swapped NV RAM chip?
Do you have PC3000 UDMA?
PostPosted: November 23rd, 2009, 8:04
OK, now I've hot swapped I think the donor NVRAM infomation has written itself to the patient SA. I'll need a PC3K UDMA to access the factory mode settings to get a reserved copy of the patient NVRAM back.
0161 408 4857
PostPosted: November 23rd, 2009, 8:36
did you back up SA before hotswap?
Users browsing this forum: No registered users and 282 guests
