 Post subject: Wrong power adapter used - external WD10EAVS now dead
PostPosted: November 29th, 2009, 4:48
I used the incorrect power adapter on my external Western Digital sata HDD and now it refuses to power up - it is acting as if a fuse has blown on the pcb - does anyone have experience of this? - I can't find anything that looks like it could be a fuse.
the pcb is a 2060-701590-000 REV A' with a Samsung chipset.
Alternatively, does anyone know where I can source a replacement PCB - I am aware that i need to swap the rom chip if I do this.
Thanks,
Dan
 Post subject: Re: Wrong power adapter used - external WD10EAVS now dead
PostPosted: November 29th, 2009, 5:14
Are you sure, your pcb have external ROM chip?
Janos
PostPosted: November 29th, 2009, 6:32
You CANNOT simply swap the PCB on the model, there not an external ROM chip. It's programmed into the MCU (large chip in the centre of the PCB).
You need to either...
1. Repair the original PCB
2. Read the ROM from the bad PCB and program a new one, or..
3. Manufacture new ROM info from the SA information on the platters
2&3 require specialist tools like PC3000
I can do this, of course.
PM me if you're interested.
This case is unfortunately not DIY'able.
PostPosted: November 29th, 2009, 7:13
Pcimage is right.
You can't solve the problem without professional electronic repair knowledge or special tools wich are really expensive...
Additionally he is near you, and can solve the problem for you easily.
Janos
PostPosted: November 29th, 2009, 20:00
Can you upload a detailed photo of your PCB?
PostPosted: November 29th, 2009, 22:20
i don't think this PCB have ROM chip. i can handle this kind of case.
data recovery service[/b]
PostPosted: December 1st, 2009, 20:10
Yes unfortunately Western Digital have still not put effective TVS diodes on their PCBs. In the ROYL series drive (which you have) the ROM has been integrated to the large chip. There's no way you fix this yourself. Most annoyingly if you had a power surge on a Seagate or a Samsung it would just be a case of removing / replacing the TVS or fuses.
0161 408 4857
Users browsing this forum: No registered users and 266 guests
