 Post subject: 7200.11 3 Bricked HDDs
PostPosted: November 29th, 2009, 16:27
I have a question. I think I cooked 3 HDDs a the same time, a Seagate 1TB 7200.11, and two 500GB Seagate 7200.11.
My power supply is an old Tagan BZ 700W running a EVGA x58 with a Core i7 @ 4.0Ghz, along with my ATI 5970, and 4 HDDs. One of the 500GB does spin, but comes up as 0MB in BIOS and not initialized in Computer Management. (Which seems more of a 7200.11 firmware problem than anything) I've tried two different computers on the two that wouldn't spin with no success, along with changing the rails the HDDs boot from with no success either. After swapping the PCB on the working one to the 500GB that wouldn't spin, I got a slight spin, although its mostly low clicking. My question is did my rail just blow up the 3 board on the HDDs? I was going to sell these as I got 3x 1.5TB Seagates during BF, but they are all filled with old camcorder movies/important very unlooseable information to me. (One of a kind items and concerts that only I have ATM). If I just have to change out PCB's (Which I think it sounds like), I wouldn't mind.
ST3500320AS
9QM34V2V
ST3500320AS
9QM6MTFQ
ST31000340AS
9QJ0V6B3
 Post subject: Re: 7200.11 3 Bricked HDDs
PostPosted: November 29th, 2009, 19:51
Can you upload detailed photos of the PCBs of the two drives that don't spin?
Here are repair procedures for Seagate 7200.11 drives affected by the BSY / 0 LBA firmware bug:
http://sites.google.com/site/seagatefix/
http://www.msfn.org/board/index.php?showtopic=128807
See the following technical bulletin:
http://atulchitnis.net/files/seagate.pdf
AIUI, the abovementioned firmware bug does not prevent an affected drive from spinning up.
PostPosted: November 29th, 2009, 22:14
hi,
you need to change ROM chip also if you swap PCB.
data recovery service[/b]
PostPosted: November 30th, 2009, 3:00
I'm looking for the following PCB/ROM.
S/N 9QJ0V6B3
ST31000340AS
P/N 9BX158-568
Firmware SD81
Date Code: 08452
Site Code: KRATSG
WWN: 5000C5000cd50a17
S/N 9QM34V2V
ST3500320AS
P/N 9BX154-303
FIRMWARE: SD15
DATE CODE: 08397
SITE CODE: KRATSG
WWN: 5000C5000B9F770D
Users browsing this forum: No registered users and 104 guests
