 Post subject: WD5000BEVT-00ZAT0. Mercury ROM MODEL. SA problem
PostPosted: December 3rd, 2009, 6:28
Hello everybody!
I have one WD5000BEVT-00ZAT0, with Mercury ROM model. I pluge in the PC3000 and It's shown "WCD ROM MODEL <MERCURY>". So I think It have SA problem, I checked and the module 02 is damage, then I need the SA modules to repair it, but is not in PC soport. Also maybe the Rom is corrupted too.
Anybody have it?
 Post subject: Re: WD5000BEVT-00ZAT0. Mercury ROM MODEL. SA problem
PostPosted: December 3rd, 2009, 6:39
Module 02 is configuration module. If this is damaged then HDD will identify as 'WDC ROM', I do not think ROM is damaged. You need change module 02 from same model HDD. I do not think I have this module, but I will look for you
PostPosted: December 3rd, 2009, 6:48
Thank you! I was thinking the same. I hope you have!
PostPosted: December 3rd, 2009, 7:45
composite read?
PostPosted: December 3rd, 2009, 8:52
guru wrote:
composite read?
Yes, available for PC3000.
Thanks!
Users browsing this forum: No registered users and 51 guests
