 Post subject: Seagate ST31000340A firmware SD 35 , is this firmware defect
PostPosted: December 4th, 2009, 5:03
Friends i need your guidance to save my family photographs.
My external hard disk suddenly gives data reading error so i removed it from casing ( seagate free agent)
when i try to connect to desktop , i could see my data but i could not copy anything. I tried to clone recover data using techassist byteback on dos , here i could go upto certain sectors but disk gives lot of bad sectors.
I have read that seagate has shipped millions of disks with some engineering defect.
However seagate site does not show this model in affected list.
http://forums.seagate.com/stx/board/mes ... e.id=13540
Is it safe to apply rs232 method suggested in this forum? will that make further complications ? any suggestion or advice please.
 Post subject: Re: Seagate ST31000340A firmware SD 35 , is this firmware defect
PostPosted: December 5th, 2009, 9:42
In case the drive does report its correct ID and capacity, and u can read some sectors, it is not very probable having FW problem, and surely not the usual translator defect.
I suspect something head related in this case...
PostPosted: December 5th, 2009, 11:02
Agree with pepe, the drive has bad sectors and/or weak/defective head(s).
You could try cloning to a good drive with non-windows based software, such as dd_rescue ot Media Tools pro. But if it starts making any strange noises then stop right away and seek pro assistance.
PostPosted: December 7th, 2009, 12:24
Thanks pepe , pcimage. I have got all my data. One of my friend managed to reverse clone disk & my data was in last partitions. He diagnosed weak heads , which gave error when accessing zones they cover.
PostPosted: December 7th, 2009, 17:44
good one, thx for the feedback
Users browsing this forum: Google [Bot] and 60 guests
