 Post subject: Seagate terminal log what's wrong with HDD ?
PostPosted: December 6th, 2009, 6:13
Hi, everybody !
I've got HDD:
Barracuda 7200.7 80 Gbytes
Model:ST380011A
1. Hard drive doesn't visible in BIOS.
2. After power suply connected I hear periodicial clicking (after each click in terminal I see code:
Head Mask 0000
Hear is log from terminal:
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk    S.15  01-16-03 11:51
Buzz  - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head
Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 -
Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0
000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head M
ask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - H
ead Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 000
0 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mas
k 0000 - юHead Mask 0000 - юHead Mask 0000 - Head Mask 0000 - Head Mask 0000 - H
0 - Head Mask 0000 - Head Mask 0000 - Error Reading Reserve Track Defect List
F>
1. What happend with this drive ?
2. Can information be recovered and how ?
3. If I don't need information the drive is alive or not ?
 Post subject: Re: Seagate terminal log what's wrong with HDD ?
PostPosted: December 6th, 2009, 6:39
Looks like bad/weak/dirty heads.
If you don't need the infomation then bin it.
PostPosted: December 6th, 2009, 7:28
So you think there are no chanсes for this HDD ?
PostPosted: December 6th, 2009, 9:25
Chances for recovery, yes.
Chances for repair and re-use, no.
PostPosted: December 6th, 2009, 9:35
OK, thanks.
What steps I have to follow to recover data from this HDD ?
PostPosted: December 6th, 2009, 11:09
You have to send it to a pro.
www.datarecoveryne.com
PostPosted: December 7th, 2009, 4:26
you got head problem.
data recovery service[/b]
PostPosted: December 7th, 2009, 8:58
Yes I see that I've got problem with Head 0.
Maby there is problem with power suply on commutator -5V ?
PostPosted: December 7th, 2009, 17:41
yes, the problem can be related to the -5V alimentation, but in 95% of the cases the cause is head/preamp related.
Users browsing this forum: Bing [Bot] and 99 guests
