 Post subject: Fujitsu - MHT clicking but heads are good
PostPosted: December 7th, 2009, 12:35
Hail to all Gurus.
I have Fujitsu MHT2040AH PL, FW: 02F9-006C. Drive spins up and then starts clicking, but not hard/loud. Stops after a while and switching to DRD DSC but no ID.
I took heads from good working donor and swapped them across. Now donor drive works OK with those heads but patient drive behaves exactly the same. Checked in Kernel mode and read ROM (PC3K shows ROM Info FW: D0-006C) and it seems to be OK. What could be the problem? Any ideas?
Thanks,
yco.
 Post subject: Re: Fujitsu - MHT clicking but heads are good
PostPosted: December 7th, 2009, 13:21
pcb?
PostPosted: December 7th, 2009, 14:14
A
HDD Spaz wrote:
pcb?
Already tried that, the same symptoms. Just guessing - SA/ROM corruption. Any chance to restore it?
PostPosted: December 7th, 2009, 14:19
yco wrote:
A
HDD Spaz wrote:
pcb?
I have some idea, i had some similar cases before...
I can try it if you want, for reasonable price.
Janos
PostPosted: December 7th, 2009, 17:45
Did you match firmware on donor to patient or swap ROM from patient to donor PCB?
PostPosted: December 8th, 2009, 3:13
I do not think MHT rom has adaptive info, so pcb swap with matching rom might help.
When you get dsc drd can you get SA access?
PostPosted: December 8th, 2009, 5:56
I tried just PCB swap and also transplanted ROM chip, still the same.
No, no access to SA, ID not detected.
PostPosted: December 8th, 2009, 6:54
what happens with hotswap?
PostPosted: December 8th, 2009, 10:54
Probably physical damage in SA area of disk.
PostPosted: December 8th, 2009, 15:10
is the drive supported within your pc3k, depends on what version you have some models aren't supported... just a suggestion
PostPosted: December 9th, 2009, 8:24
What do you mean HDD Spaz? How to do hot-swap with clicking drive?
Well not exactly, I used MHT2xxxAT utility, but does it make any difference?
PostPosted: December 9th, 2009, 14:56
no that wouldnt make a difference if its that close, you would be able to access the ID but not get to the firmware of the drive
PostPosted: December 9th, 2009, 16:09
I thought that mht family had adaptives in rom and pcb were unique... I had a mht2080ah with dead heads. Headswapped, and imaged the patient with donor pcb. Nothing but clicking using patient's pcb...
Users browsing this forum: Bing [Bot], Google [Bot] and 250 guests
