 Post subject: any ideas re a HDD I have - I've attached audio of the noise
PostPosted: December 7th, 2009, 19:40
any ideas re a HDD I have - I've attached audio of the noise it's making - I can't get windows to even recogize it?
File comment: hard disk drive noise
hdd_noise.zip [43.34 KiB]
Downloaded 268 times
 Post subject: Re: any ideas re a HDD I have - I've attached audio of the noise
PostPosted: December 7th, 2009, 20:58
A model number would be handy, but you are facing a seized bearing, or stuck heads surely.
PostPosted: December 7th, 2009, 22:30
thanks - the model was Western Digital 1TB SATAII HDD 16M Cache Green Power
does this help?
PostPosted: December 8th, 2009, 1:03
Yep, you got a stucked motor or the platters are not spinning. DO NOT POWER ON this drive any further if you want your data back. I would say, send it in for the recovery in your area.
PostPosted: December 8th, 2009, 1:15
oh thanks - if the data isn't that important is there something I try to have a crack at fixing? i.e. opening it up/
PostPosted: December 8th, 2009, 4:06
No, there is nothing you can do.
RMA it.
PostPosted: December 8th, 2009, 5:18
RMA?
BTW the drive of course is about 1-2 months just out of warranty. Is it just me or is the disk drive reliability been dropping quite a bit over the last couple of years
PostPosted: December 8th, 2009, 19:31
check the warranty in the WD website.
Normaly is 3 Years warranty.
ZeBong
" Россия еще раз"
Users browsing this forum: Google [Bot], michael chiklis and 83 guests
