 Post subject: Donor Drive for Seagate ST9160821AS
PostPosted: December 9th, 2009, 9:38
Hi All
I am a bit of an amateur techie and I am learning about data recovery as it is a job I would like to get into.
I am attempting to fix a faulty Seagate HDD (model in subject line) and it is just ticking not spinning, it looks like the PCB has fried as there are burn marks on the board. I am using it for training purposes so no data loss risk to anyone.
My question is when looking for a donor drive what should I been looking for in terms of another PCB for this drive?
 Post subject: Re: Donor Drive for Seagate ST9160821AS
PostPosted: December 9th, 2009, 10:37
Alternatively if anyone has a PCB that matches these details I would be willing to buy it off of you
Seagate Momentus 5400.3 160GB
Model no - ST9160821AS
SN: 5RN04VDR
PN: 9S1134-042
FW: 3.CAE
Date: 07467
Site: WU
PCB Part no 100398688
:D
PostPosted: December 9th, 2009, 10:43
good luck, those usually have media damage
PostPosted: December 9th, 2009, 10:44
I have a PCB for this drive, but those models of Seagate, which was made for Apple, tend to have very nasty media damage in most of the cases, so board replacement won't help.
If your drive is ticking and not spinning, its most likely a head stiction.
www.datarecoveryne.com
PostPosted: December 9th, 2009, 11:06
Sorry, I misinformed you in my first post, the drive is in fact spinning, do you think it is still worth changing the board?
PostPosted: December 9th, 2009, 12:58
If it is spinning and clicking then I'd say probably not.
PostPosted: December 9th, 2009, 13:34
99% its not a board.
PostPosted: December 9th, 2009, 17:10
OK thanks for your advice.
PostPosted: December 9th, 2009, 17:54
DR 101:
Lesson 1; Post a terminal log.
