Forum rules
 Post subject: WD StableTrac
PostPosted: December 22nd, 2009, 16:58
Hi to all,
Find this info :
The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking, during read and write operations.
(2 TB models only)
http://www.wdc.com/en/flash/index.asp?family=stabletrac
I was thinking that the plattes dont make the 1 movement.
Would like to know any comments in this :
ZeBong
" Россия еще раз"
 Post subject: Re: WD StableTrac
PostPosted: December 22nd, 2009, 17:37
can you re-phrase your question?
PostPosted: December 22nd, 2009, 18:05
WD says that a standard drive can make vibration in normal work.
I was a little bit suprise because i am making some platter exchange in Seagate and sometimes i can have a little vibration, and other times when the vibration is a little high i am having problems in cloning the disk.
Is this normal situation just in WD drives, and the new models 2TB have this problem solved by the WD engineres.
ZeBong
" Россия еще раз"
PostPosted: December 22nd, 2009, 18:24
Zebong,
My opinion is this:
This is only "bullshit". :D
This is only a marketing technique.
Yes, the 2 side tightening helps to stabilize the rotation, but in 2TB drive is because the WD can't solve this in onther way. :D
So they are "forced" to use the 2 screw and they needed to say something and this way the best solution: figure out something interesting name and call this as new technology - wich have all the IBM, maxtor and more drives back in the '00. :mrgreen:
Janos
PostPosted: December 22nd, 2009, 22:33
Right, sounds like all this means is they started putting a screw through the spindle from the top (WHAT A TECHNOLOGICAL BREAKTHROUGH)
Users browsing this forum: No registered users and 108 guests
