 Post subject: Help needed: WD10EADS-00L5B1
PostPosted: January 5th, 2010, 4:44
I have a WD10EADS-00L5B1 (Kermit) HDD which has some corrupted modules including
loader module. If you have resources of the same drive please share it with me.
Details:
Model: WD10EADS-00L5B1
Date: 20 APR 2009
DCM: DANNNT2CFN
Firmware: 01.01A01
Firmware version: 000500C5 (I need modules of this version)
(My donor drive dated 23 March 2009, has firmware version of 000500C2 which in not compatible)
Please have a look at attached screen shot for more details or for any possible advise regarding
recovery of data from this drive.
Thank you
Pninja
File comment: Screenshot of patient drive
 Post subject: Re: Help needed: WD10EADS-00L5B1
PostPosted: January 5th, 2010, 4:50
can you read sa tracks? if you can, make a full backup of BOTH sa heads. if you send me the backup i can see if it is possible to extract the modules.
PostPosted: January 5th, 2010, 7:54
Good Day
i have also same problem with same model Drive firmware version 000500CE .
PostPosted: January 5th, 2010, 7:57
Some heads are faulty
PostPosted: January 5th, 2010, 8:18
agree with terranova. but backup of sa tracks could be possible. extraction of modules is neccesary for hot swap.
PostPosted: January 5th, 2010, 8:36
YES, I have full backup of SA tracks on both SA heads.
Do I have to send you all tracks?
PostPosted: January 5th, 2010, 8:43
yes. in case of single sector defects in sa i need both sa backups. it just increases chances. can you send me donor sa backup as well (i mean both 000500C5 and 000500C2, for my database) ? zip file would be preferable.
PostPosted: January 5th, 2010, 8:47
Hi TerraNova,
Head test says all heads are OK.
I believe we can trust it :?
PostPosted: January 5th, 2010, 8:53
itconcept wrote:
Good Day
You are lucky guy. I think I have all modules of 000500CE version.
If you need them let me know?
PostPosted: January 5th, 2010, 8:59
Ok. I'll send you Zipped tracks of patient and donor tomorrow.
It is late night here and I don't have access to my database right now.
PostPosted: January 5th, 2010, 9:09
ok, i'll see what i can do to help.
PostPosted: January 5th, 2010, 10:27
pninja wrote:
Hi TerraNova,
No, you can't.
http://www.datasaversllc.com
PostPosted: January 5th, 2010, 19:45
jono-ats wrote:
pninja wrote:
Hi TerraNova,
No, you can't.
WHY?
PostPosted: January 5th, 2010, 23:20
You should ask Ace Lab this question. I have my own theories.
Suffice it to say that sometimes heads will pass the heads test, but you still cannot read customer LBAs. If a head passes the test but doesn't function in Data Extractor, then it is bad.
PostPosted: January 6th, 2010, 0:28
jono-ats wrote:
pninja wrote:
Hi
No, you can't.
On this type (green label), head swap is pretty easy. So I did a head swap today.
Unfortunately, nothing changed.
Original head also worked fine on donor drive.
In very very rare cases I have seen a faulty head passing the tests.
That is why I normally trust the head test until I have no choice other than
the head swap.
PostPosted: January 6th, 2010, 0:37
Start in kernel mode
Do head map edit on the fly - turn off all but #2
Do soft reset
See if you can get drive ID
See if you can access SA
(may have to exit utility & re-enter w/o powering off to access some SA features)
PostPosted: January 6th, 2010, 1:22
Hi jono-ats,
I don't say that head-test algorithm of ACE lab is absolute or perfect, it just helps
me to decide the head-swap as a first or last action in my data recovery process.
As to your example, I think you didn't choose a good example in this case. Head test
routine tests heads based on their physical parameters, while accessing usre LBAs in
data extractor involves logical parameters and translator tables too. Failing to access user
LBAs doesn't mean a faulty head necessarily. Please correct me if I am wrong.
PostPosted: January 6th, 2010, 1:25
Do soft reset
I did it. Drive ID or SA was not accessible.
Anyway, thank you for the hints.
PostPosted: January 6th, 2010, 2:12
Is very easy case , easy drive , heads works , only you need some commands to get all the data back.
PM if you interesting.
XRONIS
T3 Professional Data Recovery
http://www.t3-recovery.com
Users browsing this forum: Google [Bot] and 76 guests
