 Post subject: WD10EAVS-00D7B1
PostPosted: January 5th, 2010, 8:21
Hi
i am newbie i have WD10EAVS-00D7B1 F/w:000500CE it was showing 0MB capacity not showing Model i tried to access RAM head Map change it is not allowing showing no head found i rewrite ROM unfortunately i selected wrong ROM now it is not detecting i checked with Jumpers also Thanks for any Help PCB Number is 2061-701590-A00 AC
 Post subject: Re: WD10EAVS-00D7B1
PostPosted: January 5th, 2010, 8:30
Why are you playing around with the rom?
Zero Alpha: zeroalpha.com.au
PostPosted: January 5th, 2010, 9:20
is it possible to Repair it or i can Change ROM chip i have Resources Backup please let me know which is the ROM chip Thanks for any comments.
PostPosted: January 5th, 2010, 10:21
You'll need special gear to rebuild the ROM from the SA, assuming that you don't have other mechanical or PCB issues.
http://www.datasaversllc.com
PostPosted: January 5th, 2010, 10:37
Thanks for reply jono-ate by mistake i rewrite wrong ROM when i plug power on in Pc3000 all lights are showing drive is not taking power also.
PostPosted: January 5th, 2010, 10:53
The ROM is in the MPU in this series and you need a SMT station to change it out. Easiest approach would be buy a compatible donor, swap PCB, and rebuild ROM from SA with PC3000. If you don't know what you are doing you should find someone who can help you, or you may ruin ROM again.
PostPosted: January 5th, 2010, 11:22
The drive is not spinning? You wrote the wrong ROM ? Oh dear..
You need a data recovery company that knows how to circumvent the Embedded ROM. If you have a copy of the original ROM it will be a great help to whoever you choose to help you with this.
https://www.mjm.co.uk/
PostPosted: January 6th, 2010, 1:47
Totally agree with Jono-ats...
XRONIS
T3 Professional Data Recovery
http://www.t3-recovery.com
Users browsing this forum: No registered users and 114 guests
