 Post subject: installation problem of window xp
PostPosted: January 12th, 2010, 10:44
Dear Friends
when i installed windows xp, the during installation when time remain 34 minst the xp installation halt , kindly guide about this problum briefly. thanks
 Post subject: Re: installation problem of window xp
PostPosted: January 12th, 2010, 11:35
Check power supply.
PostPosted: January 12th, 2010, 11:48
- change power supply
- check cd rom for dirt / scratches
- change cd rom drive
- low level format hard disk (mhdd)
- change ide cabel
- use different memory module(s)
- check cpu fan - heat problem of cpu
- problem of graphic card (fan of graphic card)
- check the condensers (around the cpu) for rose spots on the top and/or whether there are blown up tops
If none of above works - try a different mainboard and cpu
Simple - isnt it? :roll:
PostPosted: January 21st, 2010, 3:00
It's probably the CD, I had the same problem before and it was because of the damaged CD.
Call Center Outsource
PostPosted: May 15th, 2010, 9:49
try another CD/DVD Drive and see if that works?
Users browsing this forum: No registered users and 86 guests
