 Post subject: ST360020A spins up, no access
PostPosted: January 13th, 2010, 8:41
The other drive sitting here is a Seagate ST360020A. It spins up normally, seems to init and then waits for eternity.
Tomorrow I'll check whether it becomes RDY and as what it identifies itself. The Firmware is 3.39, is there anything bad to expect..?
Do these Seagate have a serial terminal which is as useful as the terminal of the new ones?
 Post subject: Re: ST360020A spins up, no access
PostPosted: January 13th, 2010, 19:15
I gave it a try with MHDD: permanently BSY. For a head or SA fault I'd have expected it to knock, a terminal connection would probably clarify things.
PostPosted: January 13th, 2010, 20:04
yes, post terminal log
PostPosted: January 13th, 2010, 20:27
CE Log issue?
PostPosted: January 14th, 2010, 7:06
Here we go - the drive is jumpered as "single or master".
Intf tsk rst 1024k x 16 buffer detected
Ref 010D - Hd Msk 0A00 - Switch to full int.
Ready
ATRst
U6 - ST360020A(S),03.39
.PHMstr with Non-conform'gSlv
AT Er 00 Nwt Er 37 RdWr 09e6.02.0152
ATA St d0 Er 00 Op c8 e, 05fea97,08 04 03
Niwot: 005fea97 36 09e6.2.14f 8000 07c0 0240 0000
W0,LBA S005fea97,E=005fea9a,H07c3, Serr=07C3
AT Er 00 Nwt Er 43 RdWr 0071.00.002d
ATA St d0 Er 40 Op c8 e, 05fea97,08 04 03
Niwot: ffffffff 2e 0000.7.837 07c3 09e6 2152 ea9a
ATRst
HMstr with Non-conform'gATRst
(repeating from HMstr with Non....)
PostPosted: January 15th, 2010, 4:06
Thats a wierd error with U6 .
PostPosted: January 15th, 2010, 10:37
Yeah :)
Anyone who ever fixed it?
PostPosted: January 17th, 2010, 8:53
No one..?
