 Post subject: wd2500JD-75HBB0 pcb swap help
PostPosted: September 27th, 2008, 16:56
Hi folks,
I have a wd2500JD-75HBB0 that died on me, stopped working , no warning, nothing. It does not show in the BIOS.
I have replaced the old PCB. I am getting the drive to spin up and down now but am getting 6 clicks repetively.
(4 constant clicks followed by 2 clicks)
FYI-I have not swapped the ROM
Any suggestions? please.
Thank you very much,
sammad
 Post subject: Re: wd2500JD-75HBB0 pcb swap help
PostPosted: September 27th, 2008, 18:19
swap the ROM
PostPosted: September 27th, 2008, 19:06
Thanks so much for the reply.
Can you give me an idea as to how to do this.
Im not sure what chip it is and how to de-solder/re-solder it.
I have enclosed a picture.
Thank you
sammad
PostPosted: September 27th, 2008, 19:13
U12
Janos
PostPosted: September 27th, 2008, 19:45
Can you tell me what chip is the U12 please as well as a technique to get it off and back on please. I would greatly appreciate it.
Thank you
sammad
PostPosted: September 27th, 2008, 20:40
U12 is the 8 Pins IC
PostPosted: September 27th, 2008, 20:50
Got it! Now I see it. Is there a "best way" to do this. What part do I heat to remove this? The legs? The chip?
Long story short, Im a novice to soldering, however, I will give it my best.
Any help is appreciated. And thanks so much for all the replys!
sammad
PostPosted: September 28th, 2008, 3:25
Hi, if you not used to soldering I would suggest you to take the Pcb to a eletronic repair shop and ask them to do the change.
Best Regards
Bosse
http://www.rescue-it.se
PostPosted: September 28th, 2008, 8:36
Best Regards
Bosse
Agree with Bosse, if you damage the chip while taking it off, it'll make your recovery a lot, lot more difficult!
Where are you based?
PostPosted: September 28th, 2008, 8:45
I'm in the USA, Pittsburgh Pennsylvania
Thank you
sammad
PostPosted: September 28th, 2008, 12:02
Just take the PCB to any electronic technician and tell him
to replace the new 8 pins IC on the new PCB with the old one
on the old PCB
PostPosted: September 28th, 2008, 16:52
I will look for an electronic technician. I will post results.
Thanks for all the post folks!
sammad
PostPosted: October 22nd, 2008, 22:32
The ROM swap worked perfectly. A special thanks to harddrivespecialist who provided the PCB as well as the soldering.
Very honest and dependable work. I would highly recommend his services to anyone, and I would not hesitate going back to him in time of need,
Thank you to everyone who replied to this thread as well.
Sammad
PostPosted: January 15th, 2010, 1:51
Is it necessary to swap the ROM in every case of a PCB swap on a wd2500JD-75HBB0?
PostPosted: January 15th, 2010, 16:52
On this model, YES!!!
PostPosted: January 16th, 2010, 1:22
If you do have right software and hardware you can just read than write flash to working lb. Physically moving chip is in need only if lb doesn't respond to data request. Anyway I"m happy for anyone get data back.
Good Luck
http://www.datarecovery.net
Users browsing this forum: Google [Bot] and 148 guests
