Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: WD10EAVS 1.0 TB
PostPosted: December 28th, 2009, 15:47
My WD10EAVS has got some overvoltage (20V instead of 12V). :(
Where can I get a new pcb for it ?
Heinz
 Post subject: Re: WD10EAVS 1.0 TB
PostPosted: December 28th, 2009, 15:50
Online
Have the PCB get burned ?
post a picture, to see the damadge if visible.
ZeBong
" Россия еще раз"
 Post subject: Re: WD10EAVS 1.0 TB SATA
PostPosted: December 28th, 2009, 15:58
no, nothing to see, but the HDD don't work
USB Case is ok, power supply is ok
PostPosted: December 28th, 2009, 16:07
Maybe chip on block-heads (inside HDD) is damage!! Check it.
PostPosted: December 28th, 2009, 16:20
Online
do not do that.
ZeBong
" Россия еще раз"
PostPosted: December 28th, 2009, 17:42
Don't open your drive in any circumstances!
Does your drive spin up? Makes any noises?
www.datarecoveryne.com
PostPosted: December 28th, 2009, 17:52
the HDD is dead
PostPosted: December 28th, 2009, 17:59
Online
heinzrm wrote:
the HDD is dead
Is your data Important ?
Read THIS :
http://forum.hddguru.com/diy-what-the-big-deal-t12671.html
ZeBong
" Россия еще раз"
PostPosted: December 28th, 2009, 18:39
heinzrm wrote:
the HDD is dead
PCB replacement would be a good start, but this model has unique adaptive data stored in processor.
Start by searching TVS chip on this forum.
Do some tests and report your results here.
PostPosted: December 29th, 2009, 3:20
If you want someone to help you, post a photo of the component side of your PCB.
PostPosted: December 29th, 2009, 10:05
zebong wrote:
do not do that.
I mean Check it with analyser!!!
PostPosted: December 29th, 2009, 11:40
do you want to repair the drive or do you need the data ?
i am in germany maybe i can help. i have two of these drives with working pcb's. anyway posting a photo of hdd's top cover and both sides of pcb does help.
PostPosted: December 29th, 2009, 14:35
hi i have just finished posting a new topic on the same wd drive. swersig could you tell me if a replacement would work..? you have one..?
PostPosted: December 29th, 2009, 15:31
well simon75, cant find your new post...
you cant just replace the damaged pcb with any 'looking the same'. you have to make sure that flashed part of firmware on replacement pcb matches firmware on patient platters and of course you have to use the adaptives from the patient drive if possible. so there are two ways:
1.repair the damaged pcb
2.get flash rom content from damaged pcb and write it to another electrical compatible pcb.
solution 1 is often quite simple if only tvs are damaged and the preamp inside the disk is ok but it can be challenging and you may need to know some things about electrics.
if solution 1 does not work you can try solution 2. often you can read the flash rom of damaged pcb with external reader but the pcb needs to have an isolated rom chip (not the case with this disk).
in any case you have to make sure that the preamp is ok otherwise you may damage the replacement pcb and you start all over again. and a defective preamp CAN DAMAGE the data on your defective disk further making it harder if not impossible for a pro to recover your data.
if you managed to get a working pcb but the drive does not id and/or makes strange sounds its definetively a case for a pro and you shouldnt power it on any more.
hope this helps a little...
ps
i have two of these disks (see other topic) with working pcbs but other defects. they are most likely not compatible because there seem to be many different firmware versions for this disk and of course because of the adaptives. i could use my pcbs for building a donor this is why i mentioned it to heinzrm who like me lives in germany. i think there are people living/working more closely to you on this forum.
PostPosted: December 29th, 2009, 17:47
ps
thanks for the reply. i am trying to look for the tvs('s) now and i cant locate them ill take a picture and post it on my thread. i think admin is checking it before publishing. ??? as i only posted it a couple of hours or so ago. i think the first thing to do is to locate the tvs and then check its resistance. anyone interested please from now refer to my thread. so sorry for hijacking this topic but it just looked like a good place to start..
many thanks swersig
PostPosted: December 30th, 2009, 10:15
swersig,
I will remove the pcb and scan in both sides and the HDD cover.
I need the datas. My complete bookkeeping is on it, many files of clients (web design), and some other very private files (750 GB). So I don't want to give the drive into other's hands.
When I can rerun the drive, I will backup all files to another computer.
Heinz
PostPosted: December 30th, 2009, 11:57
well its your choice and i can understand if you dont want to give your drive away. you have a good chance for recovery if it is only damaged tvs otherwise you WILL HAVE to give your drive to a pro since any tingering makes the situation worse. this should be no problem since any GOOD dr company consideres private data private (take a look at the contract). you should only find one with a good reputation. if you change your mind or need help on the pcb just say so.
happy new year,
swersig
PostPosted: January 17th, 2010, 9:46
It took some time to remove the pcb - no tools ...
Now I scanned the hdd cover and both sides of the pcb.
You can dowenload it from
http://www.enp-beratung.de/downloads/WD10EAVS_1TB.pdf
Once again : the hdd got some overvoltage. 20V instead of 12V
The contacts from pcb to hdd are a little colored ...
Heinz
PostPosted: January 18th, 2010, 4:13
Check R64 and R67; probably one of them (or both) are open circuit.
Check D4 and D3; they could be short-circuited.
If so, replacing them COULD help, but it could also destroy more and make the recovery much harder.
Since it is your data, you decide :wink:
Dobre
Murphy was an optimist
PostPosted: February 19th, 2010, 14:46
Today i went to an electronic store to repair my harddisk.
It was quite simple. Important are the diodes D3 / D4
D4 was ok, D3 was replaces by a standard diode. After this, the hards disk was running again, with all datas on it .... expense : 10 Euro
Heinz
Users browsing this forum: Google [Bot] and 116 guests
